Keep getting a 504 Gateway Time-Out error
So I updated my Invoice Ninja to the latest version.
Everything was working fine. But after 2 days or so. I keep getting a 504 Gateway Time-out error.
I have used Invoice Ninja afterwards and now it gives me that error
Only thing that the Log say is that the Auto Billing is running.
I have followed this guide to install a while ago. but Then Manually updated it as it wont run the CRON job. Install Invoice Ninja v5.5 on Ubuntu 22.04
I have tried migrating but then it says that the mysql user access is denied
Are there any details about the 504 error in the web server error logs?
Can you guide me how to pull them ?
Well which log would it be ?
https://imgur.com/a/4bC95VJ
I suggest checking triggering the 504 and then checking which file was last changed
ls -lt | head
In which folder should I do that ? I see that there was a new update released 2 days ago and I pushed through that Update. But still no luck.
https://invoiceninja.micranetworking.co.za/
^ this is my invoiceninja setup but it gives me a 504 Gateway time out.
You’d run that command in /var/log/nginx
I suggest checking ininja.error.log
This is the log.
2024/03/17 08:44:03 [error] 856#856: *17164 upstream timed out (110: Unknown error) while reading respons>2024/03/17 08:44:14 [error] 856#856: *17170 upstream timed out (110: Unknown error) while reading respons>2024/03/17 09:23:25 [error] 856#856: *17698 upstream timed out (110: Unknown error) while reading respons>2024/03/17 10:44:41 [error] 856#856: *18809 upstream timed out (110: Unknown error) while reading respons>2024/03/17 10:46:33 [error] 856#856: *18809 upstream timed out (110: Unknown error) while reading respons>
Here is the .1 at the end
2024/03/16 09:00:15 [error] 824#824: *15617 upstream timed out (110: Unknown error) while reading respons>2024/03/16 09:19:19 [error] 823#823: *15857 recv() failed (104: Unknown error) while reading response hea>2024/03/16 09:23:36 [error] 854#854: *13 upstream timed out (110: Unknown error) while reading response h>2024/03/16 09:28:04 [error] 854#854: *81 upstream timed out (110: Unknown error) while reading response h>2024/03/16 09:29:51 [error] 854#854: *81 upstream timed out (110: Unknown error) while reading response h>2024/03/16 09:31:37 [error] 854#854: *81 upstream timed out (110: Unknown error) while reading response h>2024/03/16 10:24:05 [error] 856#856: *40 upstream timed out (110: Unknown error) while reading response h>2024/03/16 10:24:17 [error] 856#856: *40 upstream timed out (110: Unknown error) while reading response h>
Maybe this will help:
Well i have added those to the top of my config… Now my browser is throwing a err Connection refused error
I added the
location ~ .php$ {
  fastcgi_read_timeout 180;
To my nginx.conf file so Im not sure if that is what I was supposed to do xD
I increased the php memory limit to 512M as well but no luck.
Sorry, not sure what else to suggest.
Well while I was pushing through the update it came online… so yeah just finishing up the update and see if it comes back.
Now im getting this ;(
whilist performing “sudo -u www-data php artisan migrate”
I suggest checking the database credentials are correct in the .env file.
Where does one check that ?
