There is a file called .env in the root folder of the project
I think that solved the problem…
Changed the Database to the correct DB and changed the password as I cant remember what I set it as xD
But seems to be working now
Welp it is off again. same error. Checked the .env its still the same so I dont know what it is
I managed to download the log file.
Do you see any related errors in the log file?
I assume a 504 would be logged in the web server error logs, not the application logs.
Well I will redo the install on a different machine and see. I managed to do a export with everything so hopefully that works.
Reinstalled it on a new machine. Everything imported nicely all settings/data are there. Everything back up and running
Brilliant, thanks for letting us know!
