French Swiss Tranlation
Hello there,
I have some issues about the french tranlation because some terms are different in France, I went to Transifex, to help with the translation and try to find a Swiss French and there isn’t.
Also, in the App, I can’t find other French language than “French” and “French Canada”, but in the Transifex there’s others like “French Belgium”.
If it’s possible, I would like to have one “Swiss French” fr_CH to help translate.
Regards
You can request to create a new language in Transifex.
Nice… Thanks @hillel
I just did.
Do you know if it will begin with no translation at all or it will be like a copy of French?
And, for the App, there’s just 2 showing do you know why?
I’m not sure, I assume it would be from blank.
We only include fully translated languages in the app. Also each language currently needs its own complete set, in the future we’d like to support just loading the differences.
When you say fully, it’s in 100% translated?
Because, the version I have it’s not 100% translated.
We require 100% to add a new language, some existing languages may not be 100% translated.
Hello @hillel ,
The Swiss French is fully translated, how can I put it in the system?
@cavetech
I’d add this to my backlog to get done, can you confirm all the translations look appropriate for this locale?
Just to update, i’ve pull in this translation, however the last 800 translations have the default english translation, you’ll want to update these as it is only ~ 70% translated otherwise.
@david I think we may want to wait to add the language until we can support handling languages which are partially different.
@david ,
I’m still working on the translation, but I’m in a little hurry because of some of the translations are in the invoice and I wanted that done quickly, so I got the default english and will continue to do the rest.
