Finally I have managed to get v5 running and my next challenge is the cron job.
I have followed the instructions here:
    Morning guys
I am looking for an install guide for installing the downloaded ZIP file on WHM (cPanel).
And have this cron job set:
cd /home/alltbilling/public_html/ && /usr/local/bin/php artisan schedule:run >> /dev/null 2>&1
But still get the warning triangle
                    September 23, 2022,  6:14am
What do you see if you try running the cron command from the command line?
Good idea, I assume you mean the terminal?
                    September 23, 2022,  6:46am
                  5
              I think you 'll need to include the app folder in cd /home/alltbilling/public_html/
                    September 23, 2022,  6:55am
                  7
              If youāve named the Invoice Ninja app folder āpublicā then it would be correct
              When I did the install I set the folder as:
sub.domain.com
And when I use it I use:
sub.domain.com/#/
                    September 23, 2022,  7:09am
                  9
              I assume that was by mapping the web root to the public folder?
              Hi
I didnāt map anything to be honest, I just set the folder when I did the install and thatās what I ended up with.
This is in the .env file:
APP_URL=āhttps://sub.domain.com/ ā
                david
                    September 25, 2022, 10:27am
                  12
              The configuration looks correct to me, it may take ~24 hrs for the triangle to remove itself after the next check is run.
              Unfortunately I still have the red triangle there.
                david
                    September 27, 2022,  6:35am
                  14
              @infowhatnowebsite-co
Are you able to set a recurring invoice and see if it sends on schedule and/or reminders etc etcā¦
              I think there are bigger issues than that to be fair. I canāt do ANYTHING with an invoice, even save. I just get a 500 error if I try to save, view PDF, anything.
500: Server Error
                    September 27, 2022,  5:25pm
                  16
              Please share details about the error from storage/logs and weāll try to help
              [2022-09-27 19:57:14] production.ERROR: Call to undefined function App\DataMapper\iconv_strlen() {āuserIdā:1,āexceptionā:"[object] (Error(code: 0): Call to undefined function App\DataMapper\iconv_strlen() at /home/alltbilling/public_html/app/DataMapper/ClientSettings.php:95)#0  /home/alltbilling/public_html/app/Models/Client.php(357): App\DataMapper\ClientSettings::buildClientSettings(Object(stdClass), Object(stdClass))#1  /home/alltbilling/public_html/app/Services/Invoice/UpdateReminder.php(34): App\Models\Client->getMergedSettings()#2  /home/alltbilling/public_html/app/Services/Invoice/InvoiceService.php(278): App\Services\Invoice\UpdateReminder->run()#3  /home/alltbilling/public_html/app/Repositories/BaseRepository.php(219): App\Services\Invoice\InvoiceService->setReminder()#4  /home/alltbilling/public_html/app/Repositories/InvoiceRepository.php(35): App\Repositories\BaseRepository->alternativeSave(Array, Object(App\Models\Invoice))#5  /home/alltbilling/public_html/app/Http/Controllers/InvoiceController.php(222): App\Repositories\InvoiceRepository->save(Array, Object(App\Models\Invoice))#6  /home/alltbilling/public_html/vendor/laravel/framework/src/Illuminate/Routing/Controller.php(54): App\Http\Controllers\InvoiceController->store(Object(App\Http\Requests\Invoice\StoreInvoiceRequest))#7  /home/alltbilling/public_html/vendor/laravel/framework/src/Illuminate/Routing/ControllerDispatcher.php(45): Illuminate\Routing\Controller->callAction(āstoreā, Array)#8  /home/alltbilling/public_html/vendor/laravel/framework/src/Illuminate/Routing/Route.php(261): Illuminate\Routing\ControllerDispatcher->dispatch(Object(Illuminate\Routing\Route), Object(App\Http\Controllers\InvoiceController), āstoreā)#9  /home/alltbilling/public_html/vendor/laravel/framework/src/Illuminate/Routing/Route.php(204): Illuminate\Routing\Route->runController()#10  /home/alltbilling/public_html/vendor/laravel/framework/src/Illuminate/Routing/Router.php(725): Illuminate\Routing\Route->run()#11  /home/alltbilling/public_html/vendor/laravel/framework/src/Illuminate/Pipeline/Pipeline.php(141): Illuminate\Routing\Router->Illuminate\Routing\{closure}(Object(Illuminate\Http\Request))#12  /home/alltbilling/public_html/vendor/laravel/framework/src/Illuminate/Routing/Middleware/ThrottleRequests.php(126): Illuminate\Pipeline\Pipeline->Illuminate\Pipeline\{closure}(Object(Illuminate\Http\Request))#13  /home/alltbilling/public_html/vendor/laravel/framework/src/Illuminate/Routing/Middleware/ThrottleRequests.php(62): Illuminate\Routing\Middleware\ThrottleRequests->handleRequest(Object(Illuminate\Http\Request), Object(Closure), Array)#14  /home/alltbilling/public_html/vendor/laravel/framework/src/Illuminate/Pipeline/Pipeline.php(180): Illuminate\Routing\Middleware\ThrottleRequests->handle(Object(Illuminate\Http\Request), Object(Closure), ā300ā, ā1ā)#15  /home/alltbilling/public_html/app/Http/Middleware/QueryLogging.php(39): Illuminate\Pipeline\Pipeline->Illuminate\Pipeline\{closure}(Object(Illuminate\Http\Request))#16  /home/alltbilling/public_html/vendor/laravel/framework/src/Illuminate/Pipeline/Pipeline.php(180): App\Http\Middleware\QueryLogging->handle(Object(Illuminate\Http\Request), Object(Closure))#17  /home/alltbilling/public_html/vendor/laravel/framework/src/Illuminate/Routing/Middleware/SubstituteBindings.php(50): Illuminate\Pipeline\Pipeline->Illuminate\Pipeline\{closure}(Object(Illuminate\Http\Request))#18  /home/alltbilling/public_html/vendor/laravel/framework/src/Illuminate/Pipeline/Pipeline.php(180): Illuminate\Routing\Middleware\SubstituteBindings->handle(Object(Illuminate\Http\Request), Object(Closure))#19  /home/alltbilling/public_html/app/Http/Middleware/Locale.php(46): Illuminate\Pipeline\Pipeline->Illuminate\Pipeline\{closure}(Object(Illuminate\Http\Request))#20  /home/alltbilling/public_html/vendor/laravel/framework/src/Illuminate/Pipeline/Pipeline.php(180): App\Http\Middleware\Locale->handle(Object(Illuminate\Http\Request), Object(Closure))#21  /home/alltbilling/public_html/app/Http/Middleware/TokenAuth.php(96): Illuminate\Pipeline\Pipeline->Illuminate\Pipeline\{closure}(Object(Illuminate\Http\Request))#22  /home/alltbilling/public_html/vendor/laravel/framework/src/Illuminate/Pipeline/Pipeline.php(180): App\Http\Middleware\TokenAuth->handle(Object(Illuminate\Http\Request), Object(Closure))#23  /home/alltbilling/public_html/app/Http/Middleware/SetDb.php(40): Illuminate\Pipeline\Pipeline->Illuminate\Pipeline\{closure}(Object(Illuminate\Http\Request))#24  /home/alltbilling/public_html/vendor/laravel/framework/src/Illuminate/Pipeline/Pipeline.php(180): App\Http\Middleware\SetDb->handle(Object(Illuminate\Http\Request), Object(Closure))#25  /home/alltbilling/public_html/vendor/laravel/framework/src/Illuminate/Pipeline/Pipeline.php(116): Illuminate\Pipeline\Pipeline->Illuminate\Pipeline\{closure}(Object(Illuminate\Http\Request))#26  /home/alltbilling/public_html/vendor/laravel/framework/src/Illuminate/Routing/Router.php(726): Illuminate\Pipeline\Pipeline->then(Object(Closure))#27  /home/alltbilling/public_html/vendor/laravel/framework/src/Illuminate/Routing/Router.php(703): Illuminate\Routing\Router->runRouteWithinStack(Object(Illuminate\Routing\Route), Object(Illuminate\Http\Request))#28  /home/alltbilling/public_html/vendor/laravel/framework/src/Illuminate/Routing/Router.php(667): Illuminate\Routing\Router->runRoute(Object(Illuminate\Http\Request), Object(Illuminate\Routing\Route))#29  /home/alltbilling/public_html/vendor/laravel/framework/src/Illuminate/Routing/Router.php(656): Illuminate\Routing\Router->dispatchToRoute(Object(Illuminate\Http\Request))#30  /home/alltbilling/public_html/vendor/laravel/framework/src/Illuminate/Foundation/Http/Kernel.php(167): Illuminate\Routing\Router->dispatch(Object(Illuminate\Http\Request))#31  /home/alltbilling/public_html/vendor/laravel/framework/src/Illuminate/Pipeline/Pipeline.php(141): Illuminate\Foundation\Http\Kernel->Illuminate\Foundation\Http\{closure}(Object(Illuminate\Http\Request))#32  /home/alltbilling/public_html/vendor/sentry/sentry-laravel/src/Sentry/Laravel/Http/SetRequestIpMiddleware.php(45): Illuminate\Pipeline\Pipeline->Illuminate\Pipeline\{closure}(Object(Illuminate\Http\Request))#33  /home/alltbilling/public_html/vendor/laravel/framework/src/Illuminate/Pipeline/Pipeline.php(180): Sentry\Laravel\Http\SetRequestIpMiddleware->handle(Object(Illuminate\Http\Request), Object(Closure))#34  /home/alltbilling/public_html/vendor/sentry/sentry-laravel/src/Sentry/Laravel/Http/SetRequestMiddleware.php(42): Illuminate\Pipeline\Pipeline->Illuminate\Pipeline\{closure}(Object(Illuminate\Http\Request))#35  /home/alltbilling/public_html/vendor/laravel/framework/src/Illuminate/Pipeline/Pipeline.php(180): Sentry\Laravel\Http\SetRequestMiddleware->handle(Object(Illuminate\Http\Request), Object(Closure))#36  /home/alltbilling/public_html/vendor/livewire/livewire/src/DisableBrowserCache.php(19): Illuminate\Pipeline\Pipeline->Illuminate\Pipeline\{closure}(Object(Illuminate\Http\Request))#37  /home/alltbilling/public_html/vendor/laravel/framework/src/Illuminate/Pipeline/Pipeline.php(180): Livewire\DisableBrowserCache->handle(Object(Illuminate\Http\Request), Object(Closure))#38  /home/alltbilling/public_html/app/Http/Middleware/Cors.php(25): Illuminate\Pipeline\Pipeline->Illuminate\Pipeline\{closure}(Object(Illuminate\Http\Request))#39  /home/alltbilling/public_html/vendor/laravel/framework/src/Illuminate/Pipeline/Pipeline.php(180): App\Http\Middleware\Cors->handle(Object(Illuminate\Http\Request), Object(Closure))#40  /home/alltbilling/public_html/vendor/laravel/framework/src/Illuminate/Http/Middleware/TrustProxies.php(39): Illuminate\Pipeline\Pipeline->Illuminate\Pipeline\{closure}(Object(Illuminate\Http\Request))#41  /home/alltbilling/public_html/vendor/laravel/framework/src/Illuminate/Pipeline/Pipeline.php(180): Illuminate\Http\Middleware\TrustProxies->handle(Object(Illuminate\Http\Request), Object(Closure))#42  /home/alltbilling/public_html/vendor/laravel/framework/src/Illuminate/Foundation/Http/Middleware/TransformsRequest.php(21): Illuminate\Pipeline\Pipeline->Illuminate\Pipeline\{closure}(Object(Illuminate\Http\Request))#43  /home/alltbilling/public_html/vendor/laravel/framework/src/Illuminate/Foundation/Http/Middleware/ConvertEmptyStringsToNull.php(31): Illuminate\Foundation\Http\Middleware\TransformsRequest->handle(Object(Illuminate\Http\Request), Object(Closure))#44  /home/alltbilling/public_html/vendor/laravel/framework/src/Illuminate/Pipeline/Pipeline.php(180): Illuminate\Foundation\Http\Middleware\ConvertEmptyStringsToNull->handle(Object(Illuminate\Http\Request), Object(Closure))#45  /home/alltbilling/public_html/vendor/laravel/framework/src/Illuminate/Foundation/Http/Middleware/TransformsRequest.php(21): Illuminate\Pipeline\Pipeline->Illuminate\Pipeline\{closure}(Object(Illuminate\Http\Request))#46  /home/alltbilling/public_html/vendor/laravel/framework/src/Illuminate/Foundation/Http/Middleware/TrimStrings.php(40): Illuminate\Foundation\Http\Middleware\TransformsRequest->handle(Object(Illuminate\Http\Request), Object(Closure))#47  /home/alltbilling/public_html/vendor/laravel/framework/src/Illuminate/Pipeline/Pipeline.php(180): Illuminate\Foundation\Http\Middleware\TrimStrings->handle(Object(Illuminate\Http\Request), Object(Closure))#48  /home/alltbilling/public_html/vendor/laravel/framework/src/Illuminate/Foundation/Http/Middleware/ValidatePostSize.php(27): Illuminate\Pipeline\Pipeline->Illuminate\Pipeline\{closure}(Object(Illuminate\Http\Request))#49  /home/alltbilling/public_html/vendor/laravel/framework/src/Illuminate/Pipeline/Pipeline.php(180): Illuminate\Foundation\Http\Middleware\ValidatePostSize->handle(Object(Illuminate\Http\Request), Object(Closure))#50  /home/alltbilling/public_html/vendor/laravel/framework/src/Illuminate/Foundation/Http/Middleware/PreventRequestsDuringMaintenance.php(86): Illuminate\Pipeline\Pipeline->Illuminate\Pipeline\{closure}(Object(Illuminate\Http\Request))#51  /home/alltbilling/public_html/vendor/laravel/framework/src/Illuminate/Pipeline/Pipeline.php(180): Illuminate\Foundation\Http\Middleware\PreventRequestsDuringMaintenance->handle(Object(Illuminate\Http\Request), Object(Closure))#52  /home/alltbilling/public_html/vendor/laravel/framework/src/Illuminate/Pipeline/Pipeline.php(116): Illuminate\Pipeline\Pipeline->Illuminate\Pipeline\{closure}(Object(Illuminate\Http\Request))#53  /home/alltbilling/public_html/vendor/laravel/framework/src/Illuminate/Foundation/Http/Kernel.php(142): Illuminate\Pipeline\Pipeline->then(Object(Closure))#54  /home/alltbilling/public_html/vendor/laravel/framework/src/Illuminate/Foundation/Http/Kernel.php(111): Illuminate\Foundation\Http\Kernel->sendRequestThroughRouter(Object(Illuminate\Http\Request))#55  /home/alltbilling/public_html/public/index.php(57): Illuminate\Foundation\Http\Kernel->handle(Object(Illuminate\Http\Request))#56  {main}
                    September 27, 2022,  8:14pm
                  18
              From the error it looks like the iconv PHP extension needs to be enabled.
@david  according to this post it looks like changing from iconv_strlen to mb_strlen may avoid this issue.
  php, laravel, php-7
                david
                    September 28, 2022,  1:03am
                  19
              We have widespread usage of iconv to handle conversion from different char sets and in particular the strictness of the checks, it was a deliberate choice to use this particular function.
iconv should be a very standard inclusion in PHP, i am surprised it is not installed in the base packages.
 hillel:
iconv
I have enabled iconv and that seems to have fixed the save errors I was experiencing, thanks for that.
The CRON warning triangle is still present though, any suggestions�
