@david do you have any ideas?
I have an question, i have changed the server. so i used cpanel migration tool.
everything is the same, on the other server but i get an grey page and nog working anymore?
It may help to add ?clear_local to the end of the URL, this should enable you to login again.
i dont see any php errors… i need the invoice systemm…
have been fixt, the other host needs an DNS for subdomaining
the only thing is now that the images not working? if i upload an new logo i get 500 error
[2023-03-15 10:37:38] production.ERROR: imagecreatefromstring(): gd-png: libpng warning: iCCP: known incorrect sRGB profile {“userId”:1,“exception”:"[object] (ErrorException(code: 0): imagecreatefromstring(): gd-png: libpng warning: iCCP: known incorrect sRGB profile at /home/mdsolutions/public_html/boekhouding/app/Jobs/Util/UploadAvatar.php:40)
@david any thoughts on the error?
its an little bit urgent
? @david do u have an solution?
It may be an issue with libpng becoming more strict when checking the image. Can you attempt to use a different logo to see if it uploads ok? this will help exclude the logo being the issue.
Hello, png files gives the error, jpg files works fine?
my crons dont work anymore, when i run the command: /usr/local/bin/ea-php81 /home/mdsolutions/public_html/boekhouding/artisan ninja:send-recurring i dont get any error but the recuring invoices are not make or send…
That’s the v4 cron, the v5 cron is schedule:run
also not working anymore /usr/local/bin/ea-php81 /home/mdsolutions/public_html/boekhouding/ && php artisan schedule:run >> -q
What do you see if you run this from the command line:
