I have installed version 5.x on my VPS.
Unzip the zipfile, run the setup.
After that i get an 404 — Not Found error on the login page.
The client login page and register pages works fine…
How to fix this?
IS there someone that can help me?
January 12, 2023, 4:16pm
January 12, 2023, 4:23pm
4
Have you made any changes? I wouldn’t expect the login page to be at /login.
hi, its an clean install. made no changes, followed the setup
if you open: Invoice Ninja
it refresht everythime…
January 12, 2023, 4:49pm
7
Can you check that mod_rewrite is enabled on the server, if index.php is in the URL it’s often the reason why
mod rewrite is working, v4 is working to, but the newest version not,
administratie.md-solutions.nl = working to
I have do the following comment: php artisan migrate:fresh --seed && php artisan db:seed && php artisan ninja:create-test-data
it works, but i dont know the username/password… where to find?
find it. now have 1 more question, how to add language? i have searched but i dont can use netherlands, see 7 languages and not more…
January 13, 2023, 5:45am
11
It may help to load /update?secret= in the browser to clear the cache
david
January 13, 2023, 6:44am
12
@mdsolutions
if /update?secret=
doesn’t work, please try
/update?secret=secret
After this, just refresh the data in Settings > Device Settings > Refresh data.
fixt, but not everything is translated… how can i translate by my self?
GPSData
January 13, 2023, 1:53pm
14
I am experiencing a similar issue.
When I visit the root path, https://billing.gpsdata.io/ I see the login modal for a second, then the page auto-redirects to /login with a 404 error. If I click the “back to billing.gpsdata.io ” link on the 404 page, it takes me to the client login page.
I am unable to login to the admin backend.
I have tried the suggested, appending /update?secret= and there is no change. I actually have the same redirect happening from that uri also.
I have also tried from a different device on a different public IP and experience the same.
evertime one is fixed, the other error wil come…
now on the page if you want to change en customize the invoices…
[2023-01-13 13:59:18] production.ERROR: Call to a member function load() on null {“userId”:1,“exception”:"[object] (Error(code: 0): Call to a member function load() on null at /home/mdsolu1q/public_html/boekhouding/app/Utils/HtmlEngine.php:70)
hillel:
/update?secret=
[2023-01-13 14:02:51] production.ERROR: Call to a member function load() on null {“userId”:1,“exception”:"[object] (Error(code: 0): Call to a member function load() on null at /home/mdsolu1q/public_html/boekhouding/app/Utils/HtmlEngine.php:70)
#0 /home/mdsolu1q/public_html/boekhouding/app/Http/Controllers/PreviewController.php(337): App\Utils\HtmlEngine->__construct(Object(App\Models\InvoiceInvitation))
#1 /home/mdsolu1q/public_html/boekhouding/app/Http/Controllers/PreviewController.php(178): App\Http\Controllers\PreviewController->blankEntity()
#2 /home/mdsolu1q/public_html/boekhouding/vendor/laravel/framework/src/Illuminate/Routing/Controller.php(54): App\Http\Controllers\PreviewController->show()
#3 /home/mdsolu1q/public_html/boekhouding/vendor/laravel/framework/src/Illuminate/Routing/ControllerDispatcher.php(43): Illuminate\Routing\Controller->callAction(‘show’, Array)
#4 /home/mdsolu1q/public_html/boekhouding/vendor/laravel/framework/src/Illuminate/Routing/Route.php(260): Illuminate\Routing\ControllerDispatcher->dispatch(Object(Illuminate\Routing\Route), Object(App\Http\Controllers\PreviewController), ‘show’)
#5 /home/mdsolu1q/public_html/boekhouding/vendor/laravel/framework/src/Illuminate/Routing/Route.php(205): Illuminate\Routing\Route->runController()
#6 /home/mdsolu1q/public_html/boekhouding/vendor/laravel/framework/src/Illuminate/Routing/Router.php(798): Illuminate\Routing\Route->run()
#7 /home/mdsolu1q/public_html/boekhouding/vendor/laravel/framework/src/Illuminate/Pipeline/Pipeline.php(141): Illuminate\Routing\Router->Illuminate\Routing\{closure}(Object(Illuminate\Http\Request))
#8 /home/mdsolu1q/public_html/boekhouding/vendor/laravel/framework/src/Illuminate/Routing/Middleware/ThrottleRequests.php(126): Illuminate\Pipeline\Pipeline->Illuminate\Pipeline\{closure}(Object(Illuminate\Http\Request))
#9 /home/mdsolu1q/public_html/boekhouding/vendor/laravel/framework/src/Illuminate/Routing/Middleware/ThrottleRequests.php(62): Illuminate\Routing\Middleware\ThrottleRequests->handleRequest(Object(Illuminate\Http\Request), Object(Closure), Array)
#10 /home/mdsolu1q/public_html/boekhouding/vendor/laravel/framework/src/Illuminate/Pipeline/Pipeline.php(180): Illuminate\Routing\Middleware\ThrottleRequests->handle(Object(Illuminate\Http\Request), Object(Closure), ‘300’, ‘1’)
#11 /home/mdsolu1q/public_html/boekhouding/app/Http/Middleware/QueryLogging.php(39): Illuminate\Pipeline\Pipeline->Illuminate\Pipeline\{closure}(Object(Illuminate\Http\Request))
#12 /home/mdsolu1q/public_html/boekhouding/vendor/laravel/framework/src/Illuminate/Pipeline/Pipeline.php(180): App\Http\Middleware\QueryLogging->handle(Object(Illuminate\Http\Request), Object(Closure))
#13 /home/mdsolu1q/public_html/boekhouding/vendor/laravel/framework/src/Illuminate/Routing/Middleware/SubstituteBindings.php(50): Illuminate\Pipeline\Pipeline->Illuminate\Pipeline\{closure}(Object(Illuminate\Http\Request))
#14 /home/mdsolu1q/public_html/boekhouding/vendor/laravel/framework/src/Illuminate/Pipeline/Pipeline.php(180): Illuminate\Routing\Middleware\SubstituteBindings->handle(Object(Illuminate\Http\Request), Object(Closure))
#15 /home/mdsolu1q/public_html/boekhouding/app/Http/Middleware/Locale.php(46): Illuminate\Pipeline\Pipeline->Illuminate\Pipeline\{closure}(Object(Illuminate\Http\Request))
#16 /home/mdsolu1q/public_html/boekhouding/vendor/laravel/framework/src/Illuminate/Pipeline/Pipeline.php(180): App\Http\Middleware\Locale->handle(Object(Illuminate\Http\Request), Object(Closure))
#17 /home/mdsolu1q/public_html/boekhouding/app/Http/Middleware/TokenAuth.php(96): Illuminate\Pipeline\Pipeline->Illuminate\Pipeline\{closure}(Object(Illuminate\Http\Request))
#18 /home/mdsolu1q/public_html/boekhouding/vendor/laravel/framework/src/Illuminate/Pipeline/Pipeline.php(180): App\Http\Middleware\TokenAuth->handle(Object(Illuminate\Http\Request), Object(Closure))
#19 /home/mdsolu1q/public_html/boekhouding/app/Http/Middleware/SetDb.php(40): Illuminate\Pipeline\Pipeline->Illuminate\Pipeline\{closure}(Object(Illuminate\Http\Request))
#20 /home/mdsolu1q/public_html/boekhouding/vendor/laravel/framework/src/Illuminate/Pipeline/Pipeline.php(180): App\Http\Middleware\SetDb->handle(Object(Illuminate\Http\Request), Object(Closure))
#21 /home/mdsolu1q/public_html/boekhouding/vendor/laravel/framework/src/Illuminate/Pipeline/Pipeline.php(116): Illuminate\Pipeline\Pipeline->Illuminate\Pipeline\{closure}(Object(Illuminate\Http\Request))
#22 /home/mdsolu1q/public_html/boekhouding/vendor/laravel/framework/src/Illuminate/Routing/Router.php(799): Illuminate\Pipeline\Pipeline->then(Object(Closure))
#23 /home/mdsolu1q/public_html/boekhouding/vendor/laravel/framework/src/Illuminate/Routing/Router.php(776): Illuminate\Routing\Router->runRouteWithinStack(Object(Illuminate\Routing\Route), Object(Illuminate\Http\Request))
#24 /home/mdsolu1q/public_html/boekhouding/vendor/laravel/framework/src/Illuminate/Routing/Router.php(740): Illuminate\Routing\Router->runRoute(Object(Illuminate\Http\Request), Object(Illuminate\Routing\Route))
#25 /home/mdsolu1q/public_html/boekhouding/vendor/laravel/framework/src/Illuminate/Routing/Router.php(729): Illuminate\Routing\Router->dispatchToRoute(Object(Illuminate\Http\Request))
#26 /home/mdsolu1q/public_html/boekhouding/vendor/laravel/framework/src/Illuminate/Foundation/Http/Kernel.php(190): Illuminate\Routing\Router->dispatch(Object(Illuminate\Http\Request))
#27 /home/mdsolu1q/public_html/boekhouding/vendor/laravel/framework/src/Illuminate/Pipeline/Pipeline.php(141): Illuminate\Foundation\Http\Kernel->Illuminate\Foundation\Http\{closure}(Object(Illuminate\Http\Request))
#28 /home/mdsolu1q/public_html/boekhouding/vendor/livewire/livewire/src/DisableBrowserCache.php(19): Illuminate\Pipeline\Pipeline->Illuminate\Pipeline\{closure}(Object(Illuminate\Http\Request))
#29 /home/mdsolu1q/public_html/boekhouding/vendor/laravel/framework/src/Illuminate/Pipeline/Pipeline.php(180): Livewire\DisableBrowserCache->handle(Object(Illuminate\Http\Request), Object(Closure))
#30 /home/mdsolu1q/public_html/boekhouding/app/Http/Middleware/Cors.php(25): Illuminate\Pipeline\Pipeline->Illuminate\Pipeline\{closure}(Object(Illuminate\Http\Request))
#31 /home/mdsolu1q/public_html/boekhouding/vendor/laravel/framework/src/Illuminate/Pipeline/Pipeline.php(180): App\Http\Middleware\Cors->handle(Object(Illuminate\Http\Request), Object(Closure))
#32 /home/mdsolu1q/public_html/boekhouding/vendor/laravel/framework/src/Illuminate/Http/Middleware/TrustProxies.php(39): Illuminate\Pipeline\Pipeline->Illuminate\Pipeline\{closure}(Object(Illuminate\Http\Request))
#33 /home/mdsolu1q/public_html/boekhouding/vendor/laravel/framework/src/Illuminate/Pipeline/Pipeline.php(180): Illuminate\Http\Middleware\TrustProxies->handle(Object(Illuminate\Http\Request), Object(Closure))
#34 /home/mdsolu1q/public_html/boekhouding/vendor/laravel/framework/src/Illuminate/Foundation/Http/Middleware/TransformsRequest.php(21): Illuminate\Pipeline\Pipeline->Illuminate\Pipeline\{closure}(Object(Illuminate\Http\Request))
#35 /home/mdsolu1q/public_html/boekhouding/vendor/laravel/framework/src/Illuminate/Foundation/Http/Middleware/ConvertEmptyStringsToNull.php(31): Illuminate\Foundation\Http\Middleware\TransformsRequest->handle(Object(Illuminate\Http\Request), Object(Closure))
#36 /home/mdsolu1q/public_html/boekhouding/vendor/laravel/framework/src/Illuminate/Pipeline/Pipeline.php(180): Illuminate\Foundation\Http\Middleware\ConvertEmptyStringsToNull->handle(Object(Illuminate\Http\Request), Object(Closure))
#37 /home/mdsolu1q/public_html/boekhouding/vendor/laravel/framework/src/Illuminate/Foundation/Http/Middleware/TransformsRequest.php(21): Illuminate\Pipeline\Pipeline->Illuminate\Pipeline\{closure}(Object(Illuminate\Http\Request))
#38 /home/mdsolu1q/public_html/boekhouding/vendor/laravel/framework/src/Illuminate/Foundation/Http/Middleware/TrimStrings.php(40): Illuminate\Foundation\Http\Middleware\TransformsRequest->handle(Object(Illuminate\Http\Request), Object(Closure))
#39 /home/mdsolu1q/public_html/boekhouding/vendor/laravel/framework/src/Illuminate/Pipeline/Pipeline.php(180): Illuminate\Foundation\Http\Middleware\TrimStrings->handle(Object(Illuminate\Http\Request), Object(Closure))
#40 /home/mdsolu1q/public_html/boekhouding/vendor/laravel/framework/src/Illuminate/Foundation/Http/Middleware/ValidatePostSize.php(27): Illuminate\Pipeline\Pipeline->Illuminate\Pipeline\{closure}(Object(Illuminate\Http\Request))
#41 /home/mdsolu1q/public_html/boekhouding/vendor/laravel/framework/src/Illuminate/Pipeline/Pipeline.php(180): Illuminate\Foundation\Http\Middleware\ValidatePostSize->handle(Object(Illuminate\Http\Request), Object(Closure))
#42 /home/mdsolu1q/public_html/boekhouding/vendor/laravel/framework/src/Illuminate/Foundation/Http/Middleware/PreventRequestsDuringMaintenance.php(86): Illuminate\Pipeline\Pipeline->Illuminate\Pipeline\{closure}(Object(Illuminate\Http\Request))
#43 /home/mdsolu1q/public_html/boekhouding/vendor/laravel/framework/src/Illuminate/Pipeline/Pipeline.php(180): Illuminate\Foundation\Http\Middleware\PreventRequestsDuringMaintenance->handle(Object(Illuminate\Http\Request), Object(Closure))
#44 /home/mdsolu1q/public_html/boekhouding/vendor/laravel/framework/src/Illuminate/Pipeline/Pipeline.php(116): Illuminate\Pipeline\Pipeline->Illuminate\Pipeline\{closure}(Object(Illuminate\Http\Request))
#45 /home/mdsolu1q/public_html/boekhouding/vendor/laravel/framework/src/Illuminate/Foundation/Http/Kernel.php(165): Illuminate\Pipeline\Pipeline->then(Object(Closure))
#46 /home/mdsolu1q/public_html/boekhouding/vendor/laravel/framework/src/Illuminate/Foundation/Http/Kernel.php(134): Illuminate\Foundation\Http\Kernel->sendRequestThroughRouter(Object(Illuminate\Http\Request))
#47 /home/mdsolu1q/public_html/boekhouding/public/index.php(57): Illuminate\Foundation\Http\Kernel->handle(Object(Illuminate\Http\Request))
#48 {main}
January 13, 2023, 2:18pm
17
@david do you have any ideas?
Strange, if i load the demo data the edit invoices etc works fine, if you gonna make some changes with the company etc. there are problems
Everything i have fixt for now.
Other question, in the Netherlands the invoices are different.
Example:
i see no text before the VAT number, the housenumber stands on an other rule, in the Netherlands is: streetname + house number
Eygelshoven, Limburg 6471XB
Must be: 6471XB Eygelshoven Limburg
Look, i have upload an invoice layout of the V4 ( with the blue tables ) thats what i need and want in V5
Also, i have an licence for whitelabel. but the page title show invoiceninja, the login screen shows invoiceninja logo…
