okay, but in the language file of NL the things that are not translated are dutch in the file, but not on the site self
Can you send a specific example from the code?
The app screenshot is ‘Purchase Order’ whereas the code screenshot is ‘Purchase’
I think you may be looking at the backend code, the frontend code is here:
https://raw.githubusercontent.com/invoiceninja/admin-portal/master/lib/utils/i18n.dart
If the backend has the translation it will be included with an upcoming frontend release.
Where can i find this code on my server? in wich map?
The code isn’t on your server, it’s used to build the frontend app.
okay, but how can i changed it by myself?
You would need to rebuild the app
How :-p do i do that? hehhe
to difficult for me…
its strange that everything have been translated but that not.
Other question, how to make an costum client url?
i have now: boekhouding.md-solutions.nl
for clients and costumers i would like have: portal.md-solutions.nl
How to make this work? need i do some dns changes?
The updated translation will be included in an upcoming release.
It require updating the web server configuration.
okay, then i will wait for it!
and this?:
okay, wich configuration?
It would depend on your server.
i use cpanel, with cent os 7
