Hi @hillel , @david ,
lastest update fails with following error:
[2022-03-03 17:01:36] production.ERROR: The "/tmp/v5.3.64" directory does not exist. {"userId":1,"exception":"[object] (Symfony\\Component\\Finder\\Exception\\DirectoryNotFoundException(code: 0): The \"/tmp/v5.3.64\" directory does not exist. at /var/www/hst23/htdocs/domain.com/vendor/symfony/finder/Finder.php:590)
Prior updates on shared hosting worked just fine. The folder is not existing, but I can’t figure out, why. The app-triggered update takes to long as no update-files should be pulled to my installation. Do you have any idea?
Hi @david , the /tmp remains empty while pulling the 5.3.64 update. The tmp is unchanged ever since installtation/updates. Has something changed in update procedure in the latest version? Shared host logs don’t show anything helpful. Webspace is about 8GB left.
I also have the same issue
Log shows
[2022-03-05 14:02:31] production.ERROR: The “/tmp/v5.3.66” directory does not exist. {“userId”:1,“exception”:"[object] (Symfony\Component\Finder\Exception\DirectoryNotFoundException(code: 0): The “/tmp/v5.3.66” directory does not exist. at /home/redstonewebdesig/public_html/portal/vendor/symfony/finder/Finder.php:592)
[stacktrace] #0 /home/reds
Hi yes I Used the Secret from the .env
The Hosting provider will not help as InvoiceNinja is not their product they say to contact InvoiceNinja Support
