I’m having problems with sending reminders. In the invoices list I see that the ‘last reminder date’ is today, but no reminders are send. I have no problems with sending new invoices or recurring invoices.
Hmm I see. See the screenshot below. The last option ‘Verstuur herinneringen’ is the ‘Send reminders’ option. For all clients this is ‘blank’, no option is chosen. I don’t know what the value of this option was in the past. At least, I didn’t changed this manually.
When this is blank, I would assume that the global setting would be in place. Just like the ‘quote valid until’ and the ‘invoice payment terms’ settings.
I don’t think there is a way to do this unless you create a group setting and then apply the group to the client on creation if you have a standard set of settings
In the invoices table, can you confirm that a next_send_date is being generated for your invoices? This will tell us whether the system is actually calculating the reminder date.
First reminder - 3 days - after due date - send email = yes
Second reminder - 8 days - after due date - send email = yes
Third reminder - 14 days - after due date - send email = yes
Endless reminders - weekly - send email = yes
I’ve put EXPANDED_LOGGING=true now in the .env file.
For unknown reason, this morning (19/12) two reminders were sent. Both reminders are ‘first reminders’. Nothing changed on the configuration, I’m even still on v5.3.35-C68. Both actions are also logged in the activities logs table.
Was the second reminder sent on schedule? Within that invoice where the second reminder has been sent, if you inspect that row in the database there will be a next_send_date column, does that match the 3rd reminder schedule?
Invoice date: 02/11
First reminder: 19/11 (sent)
Second reminder: 24/11 (sent)
Third reminder: 30/11 (sent)
Endless reminder: never sent (even though the setting is set is to ‘weekly’)
I see a column ‘latest reminder’ and a column ‘next reminder’. Both have dates. The value for ‘latest reminder’ is on 28/12 (but this one is not sent). Next reminder has value 03/01.
