Upon Switching from Flutter to React, I am now faced with the infamous white screen. I have followed the steps and suggestions in the following post, but have had no luck. Help would be greatly appreciated in getting this working. There is
I have just updated from the Github to the latest release. I can easily swap back using the Database Query, however I would like to use the React UI as that is my primary interface that myself and others that use the system are used to.
Failed to load module script: Expected a JavaScript module script but the server responded with a MIME type of “text/html”. Strict MIME type checking is enforced for module scripts per HTML spec.
I am working on this at the moment. There is an issue with the react app updating itself after each version. This should be resolved in the next release.
