I have deployed Invoice Ninja on my Synology NAS (with web station) with quite a few problems.
With version 5.1.14 I have managed to perform the setup but once running the PDFs of the invoices are not generated and if I edit the templates the preview does not come out either as an error 500 appears. I also have an alert informing me that the cron must be enabled. I have searched the forum and I see possible solutions such as changing the phantom to snappdf or things like that but I do not know what to do, as I have it on NAS is not the same as other users who have it on Linux or docker.
I try to force the update from the GUI but I get a server error.
I have tried to deploy the 5.3.33 version but it does not start the setup, it appears a (very large) image of two screens and Chinese cat and at the bottom a message of 500 - Server error.
I am desperate because I can not deploy the application, all are problems
I have started everything from scratch.
I have managed to deploy version 5.3.33
I have renamed the .env.example file to .env and was able to start the setup.
thank you for replying. The log didn’t help. i get the Error 500 when choosing view a pdf.
I’ve tried a clean install of V5.3.33; installed app from app store. all give the same result. Here is my setup. Self-hosted on a Lite-speed server; tested on Safari, chrome. I’ve tried disabling ModSec. Anyone able to help with this setup? TIA
may help finding files with wrong permissions or ownerships (/path/to/invoiceninja needs to reflect your installation, www-data may need to be replaced with whatever your http daemon is running as).
xoo, thanks for your advise. I tried following but i’m not technical enough and got lost. the log file doesn’t show any 500 error. i am working on a backup. if i delete .env file will it get regenerated again with correct permissions?
thank you once again. Sorry, i can’t find any log files under var/log only vars/cpanel/styles.
I setup a new subdomain and installed a new V5.3.33.
Installed the app from app store on my mac.
Exported CSV files from my old setup and imported using phpadmin.
Installed Clients, invoices, products. opened my new setup, opened one of the invoice, view pdf…and i get Error 500 again. back to square one. just what is going on?
I checked with support at NameHero. i don’t know where to start to look.
BTW: i also installed a hosted version and View pdf gives me Error 500 again.
I installed version 4.5.46 on my Synology (using Web Station) and everything works correctly.
However in version 5 (any of the ones indicated in the title of the post) appears the message that cron must be enabled and the error 500 when editing the template because in the creation of the invoice the PDF never comes out.
What should I do to:
Enable cron.
Make the PDF generator work.
Remember that I am using NAS Synology and also I do not have much knowledge of terminal commands (that from Synology I do not know if it is possible)
cm84 sorry i have highjacked your thread. I appear to have the same issue as yours.
David, i have exhausted all my efforts and not got anywhere. I’m not a techie so sometime can’t follow some of the suggestions.
i cloned my installation to test and saved the database; tried hosted and self hosted. As much as i like IN, it’s now time to give up and look for alternative as i have wasted so much time finding a solution. there is nowhere else to look. thanks for all your patience help and support. Bye
About configuring the DNS to resolve the http… where do I configure the DNS? on the Synology NAS?
On the other hand, I don’t have white label license, at the moment I am testing different billing solutions and then I would evaluate if Invoice Ninja is the solution of choice.
I don’t really know how to solve this.
I have installed version 4 and here the PDF does work.
This will be tricky on the Synology, as most likely snappdf will not work so you will be relying on PhantomJS which requires a public IP address so that Phantom can generate the PDFs.
