Again, no docs found on this. What is the logic behind the client portal access when one client has many contacts. Let’s say there is a General Manager, Accountant and a Department Head.
Invoices go only to Department head.
In this case, can Accountant and General Manager see them in their client portal?
Really need a separate page in documentation about Client Portal…
In other words, everyone should be included in the invoice email?
What if GM doesn’t want to receive an email but would like to keep an eye on his accountant and dept. head?
That setting determines whether the contact will be added to future invoices. I suggest checking if both contacts are checked in the invoices they can see in the client portal.
I’ve logged in separately in different browsers (incognito mode) through the /client slug (direct link to the login screen). Same thing for both users.
Then logged out.
Then verified that option is on for one contact and off for another.
Created and emailed new invoice, with only one contact checked.
Logged in different browsers again, and both users can see the new invoice.
I can record the screen if you’d like.
You can set password protection on the client portal which will force anyone - including people with a portal URL - to enter their credentials prior to logging into the portal. By default password protection is disabled meaning that anyone with a valid link has direct access.
The add to invoices toggle adds a contact specific link that can be tracked when clicked to identify the contact who viewed the document.
I’m aware of passwords. It is turned ON on my side. This doesn’t explicitly restrict contacts from accessing the portal - they can just reset the password. So every contact always has access to the portal - no way to regulate this. Correct?
This is confusing the matter further. The toggle “Add to invoices” is mislabeled then. Since it responsible for personalized links, not the emails. These links will be generated for emails only, or it’s a system-wide option for personalized tracking links?
Turning it off, doesn’t change the state of the Checkbox in the new invoice/quote/credit.
I actually can’t turn it off for some reason
That is correct. They always have ultimate access to the portal.
Not sure i follow. When you toggle this on for a client, it creates a separate invitation link dedicated to that contact. I’m not sure what you mean by system wide. The invitation is unique for the contact AND the document.
If this toggle (Add to invoices) is ON - then the “INDIVIDUAL” tracking link will be generated for Email AND for the client portal.
OR
Just for the emails?
