After updating(5.7.28/5.7.30) i won’t see my invoices/clients/products/… anymore.
?update didn’t solve any problems .
Anyone who knows how to solve this ?
Thx!
Thx!
Also, can you please share the full app version you see in the about dialog?
I only get these warnings.
Version 5.7.30-C125
Have you tried logging out/in?
Also, do you see a difference when using the desktop app?
desktop/android app no difference.
Just tried to log out/login but still the same.
The only tab i can open is Supplier
Does switching to the React app help?
Are there any errors in storage/logs?
React works !!
Windows/Android apps stays the same.
Great, progress…
Do you see any errors in storage/logs?
If you’d like to add [email protected] as a limited user I can try to debug the problem.
No recent logs in storage/logs. Added contact to users.
Thx!
Thanks, I’ll let you know what I find.
I think I see the problem, the currency precision is set to 4. This isn’t supported by the app, did you manually update the database?
Precision was so to 4 because of my previous topic (Total rouding wrong on PDF).
Changed it back to 2 and now the app (windows/android) works …
Thank you for the quick response!!!
