How to put the Terms and Conditions on a separate page of the pdf?
I recently migrated from V4 to V5 (hosted), but my settings did not migrate so well. My invoices now show the T&Cs just below the products/services and total/subtotal columns, whereas I would like them to appear on a separate page.
With V4, I was able to solve the issue by adding this piece of code through the Settings / Customize design page of the hosted app:
“pageBreak”: “after”,
“columns”: [
This does not work anymore, or is not possible.
Any idea on how to resolve the above when using Hosted V5?
Thank you.
@david can you please advise?
I found this answer which seems to work: css - Google Chrome Printing Page Breaks - Stack Overflow
You’d want to add this code on the includes tab:
      div.page
        page-break-after: always;
        page-break-inside: avoid;
And then use the page class to force a break:
    <div class="page">
      <h1>This is Page 1</h1>
    </div>
    <div class="page">
      <h1>This is Page 2</h1>
    </div>
    <div class="page">
      <h1>This is Page 3</h1>
    </div>
Many thanks.
I must admit this goes beyond my programming skills…
Below is a copy of my includes tab. Would you mind at all showing me where, exactly, I ought to add the additional code?
Much appreciated.
<style id="style">
    @import url($font_url);
    :root {
        --primary-color: $primary_color;
        --secondary-color: $secondary_color;
        --line-height: 1.6;
    html {
        width: 210mm;
        height: 200mm;
    body {
        -webkit-font-smoothing: antialiased;
        -moz-osx-font-smoothing: grayscale;
        font-family: $font_name, Helvetica, sans-serif;
        font-size: "$font_size";
        zoom: 80%;
    @page {
        margin-left: $global_margin;
        margin-right: $global_margin;
        margin-top: 30;
        margin-bottom: 0;
        size: $page_size $page_layout;
    p {
        margin: 0;
        padding: 0;
    .header-container {
        display: grid;
        grid-template-columns: 1fr 1fr 1fr;
        gap: 20px;
    .company-logo {
        max-width: 40%;
    #company-details {
        display: flex;
        flex-direction: column;
        line-height: var(--line-height);
    #company-details > p:first-child {
        color: var(--primary-color);
    #company-address {
        display: flex;
    .entity-label {
        margin-top: 2.5rem;
        text-transform: uppercase;
        padding-left: 1rem;
        margin-bottom: 1rem;
        font-weight: bold;
    .client-and-entity-wrapper {
        display: flex;
        padding: 1rem;
        border-top: 1px solid #d8d8d8;
        border-bottom: 1px solid #d8d8d8;
    #entity-details {
        text-align: left;
        margin-right: 20px;
    #entity-details > tr,
    #entity-details th {
        font-weight: normal;
        padding-right: 15px;
        padding-top: 2.5px;
        padding-bottom: 2.5px;
    #client-details {
        display: flex;
    #client-details > :first-child {
        font-weight: bold;
    [data-ref="table"] {
        margin-top: 1rem;
        margin-bottom: 50px;
        min-width: 100%;
        table-layout: fixed;
        overflow-wrap: break-word;
    .task-time-details {
        display: block;
        margin-top: 5px;
        color: grey;
    [data-ref="table"] > thead {
        text-align: left;
    [data-ref="table"] > thead > tr > th {
        font-size: 1.1rem;
        padding-bottom: 1.5rem;
        padding-left: 1rem;
    [data-ref="table"] > tbody > tr > td {
        padding: 1rem 1rem;
    [data-ref="table"] > tbody > tr > td:first-child {
    [data-ref="table"] > thead > tr > th:last-child,
    [data-ref="table"] > tbody > tr > td:last-child {
        text-align: right;
    [data-ref="table"] > thead > tr > th:last-child {
        padding-right: 1rem;
    [data-ref="table"] > tbody > tr:nth-child(odd) {
        background-color: #f5f5f5;
    #table-totals {
        margin-top: 0rem;
        display: grid;
        grid-template-columns: 2fr 1fr;
        padding-top: .5rem;
        gap: 80px;
        page-break-inside:auto;
        overflow: visible !important;
    #table-totals .totals-table-right-side > * {
        display: grid;
        grid-template-columns: 1fr 1fr;
    #table-totals>.totals-table-right-side>*> :nth-child(1) {
        text-align: $dir_text_align;
        margin-top: .75rem;
    #table-totals>.totals-table-right-side>*> :nth-child(2) {
        text-align: right;
    #table-totals>.totals-table-right-side> * > :not([hidden]) ~ :not([hidden]) {
        --tw-space-y-reverse: 0;
        margin-top: calc(.75rem * calc(1 - var(--tw-space-y-reverse)));
        margin-bottom: calc(.75rem * var(--tw-space-y-reverse));
    #table-totals
    [data-element='product-table-balance-due-label'],
    #table-totals
    [data-element='product-table-balance-due'] {
        font-weight: bold;
    #table-totals
    #table-totals > * > :last-child {
        text-align: right;
    #footer {
        margin-top: 14px;
       text-align: center;
       margin-bottom: 0;
    /** Markdown-specific styles. **/
    #product-table h3,
    #task-table h3,
    #delivery-note-table h3 {
        font-size: 1rem;
        margin-bottom: 0;
    .company-logo-container {
        display: flex;
        justify-content: flex-end;
    [data-ref="statement-totals"] {
        margin-top: 1rem;
        text-align: right;
        margin-right: .75rem;
    [data-ref*=".line_total-td"] {
        white-space: nowrap;
    /** .repeating-header,
    .repeating-header-space, **/
    .repeating-footer,
    .repeating-footer-space {
        height: 10px;
    .repeating-header {
        position: fixed;
        top: 0;
    .repeating-footer {
        position: fixed;
        bottom: 1;
    [data-element='product_table-product.description-td'], td {
        min-width:100%;
        max-width: 300px;
</style>
You’d want to add the code after the opening style tag
Just to follow on,
after you have made the page break, just use the variable $terms and the terms will be injected.
Many thanks.
I tried all this, but it won’t work regrettably.
The variable $terms is built within the invoice’s “totals-table” code, which makes it impossible to split Terms, through a page break, from the rest of the table that shows the invoice’s total. As a result, the T&Cs are displayed as a column, on the page’s left-hand-side, which does not look right. Here is a screen capture:
I should perhaps consider not adding my T&Cs at all on my invoices, or having these sent to my clients as a separate attachment.
Previously, when using V4 (hosted), I was able to split the T&Cs from the remainder of the invoice. Below is an ectract of the code I used at the time.
I used " “pageBreak”: “after”,
“columns”:
and instered “$notesAndTerms” further down.
    "style": "invoiceLineItemsTable",
    "table": {
      "headerRows": 1,
      "widths": [
        "55%",
        "15%",
        "15%",
        "15%"
      "body": "$invoiceLineItems"
    "layout": {
      "hLineWidth": "$notFirst:.5",
      "vLineWidth": "$none",
      "hLineColor": "#D8D8D8",
      "paddingLeft": "$amount:8",
      "paddingRight": "$amount:8",
      "paddingTop": "$amount:14",
      "paddingBottom": "$amount:14"
    "columns": [],
    "margin": [
      40,
      -20,
      40,
      10
    "pageBreak": "after",
    "columns": [
        "table": {
          "widths": [
            "40%"
          "body": "$subtotals"
        "layout": {
          "hLineWidth": "$none",
          "paddingLeft": "$amount:34",
          "paddingTop": "$amount:6",
          "paddingBottom": "$amount:4"
  "$notesAndTerms",
  "$signature",
    "stack": [
      "$invoiceDocuments"
    "style": "invoiceDocuments"
which resulted in the Terms being on a separate page, as shown on this screen capture.
@Zeidroc Have you found a solution? I’m having the same issue
I haven’t solved the issue so far, so am stuck with invoices which display my T&Cs in a column on the first page’s left-hand side. That’s messy and does not look much professional.
It was easy to fix with V4 and I hope someone will come around with a solution for V5 too!
