Hi there,
I have my own shared host but after I extracted the files from the invoice ninja onto my site, I get a list of files and no prompt to set up the app and database etc.
By default you can access the site using the /public folder.
The best practice is to configure the site by mapping your webroot to the public folder but you may also be able to change it using the .htaccess file.
Here is the URL I’m using with this but I get 500 Internal Server error still…I’m surprised this isn’t straight forward with a simple hostgator server?
Thanks Hillel,
Was able to update my public_html/index.php it but still getting a 500 Internal Server error when trying to access the ninja invoices page. Any ideas?
[Mon Jan 25 08:38:38 2016] [error] [client 69.136.229.188] SoftException in Application.cpp:313: File “/home3/papanic/public_html/invoices.com/public/index.php” is writeable by group
[Mon Jan 25 08:35:09 2016] [error] [client 66.249.83.165] SoftException in Application.cpp:313: File “/home3/papanic/public_html/invoices.com/public/index.php” is writeable by group
Ok that helped…getting somewhere now…but got this error…
Warning: Unexpected character in input: '\' (ASCII=92) state=1 in /home3/papanic/public_html/invoices.com/public/index.php on line 52
Parse error: syntax error, unexpected T_STRING in /home3/papanic/public_html/invoices.com/public/index.php on line 52
All post I’ve found for this error are related to the PHP version. Is it possible you’re running two separate versions of PHP. It can be helpful to add a phpinfo page to double check the server (vs CLI) version.
