Global Client Changes
Is it possible to make a Global Change in the client settings?
I want to change all clients terms to Net 10.
New to InvoiceNinja, Like it very much!
John Steward
AuroraTech, LLC.
There is a “Bulk update” for clients however the payment terms isn’t available as a field, feel free to create an issue on GitHub to request it.
Note: if you’re a developer it’s possible to use tinker or the API to bulk update records, ie.
Thank you for the input. Wondering if i export the client list and make the change then reimport, will it change or duplicate the customers??
I’m not sure, I suggest testing it with a single record.
