I am trying to import all of my exported data from Invoiceasap but in order to set the correct columns for the import of clients, products, services, estimates, invoices, etc… I could not find a specific export for any of those items in Invoice Ninja so that I could use that format for my import.
In v5 you can export data to CSV using the reports.
Are there specific columns which are missing?
I can give you an example from an export of InvoiceAsap if you like but I don’t know if I can upload here
Company Name | Job Name | First Name | Last Name | Email | Contact Phone | Mobile Phone | Billing Addr1 | Billing Addr2 | Billing City | Billing State Or Province | Billing Postal Code | Shipping Addr1 Shipping Addr2 | Shipping City | Shipping State Or Province | Shipping Postal Code
I’m not sure I understand.
You should be able to map the fields when importing, are there specific fields missing?
I created a couple of test users and did a report but only had a few columns with no addresses… What do I need to import my client list, product list and services list into Invoice Ninja as far as mapping goes? I can copy my data into the correct columns but I don’t know what the column headers in Invoice Ninja need to be. That’s why I sent you a list of my column headers.
Have you tried the CSV import yet?
You can use any column headers, after you upload the file you’ll have a chance to map the columns.
Ok no I haven’t… Normally what I have done in the past is to export from the target and export from the source and copy paste information. I will try the import
THANKS @hillel, … That was VERY Easy
Now, I have products and services. What would you use for Services?
As I was attempting to import my past invoices, I am not seeing Sub Total, Tax, Total, Paid Y / N (just Balance) What would you use for those?
To import an invoice you need to set the line item qty/costs, the app will automatically calculate the total.
Ok, I will try it this morning
Is that for historical invoices as well?
This applies to all invoices imported as CSV
The only problem is that I am having an issue mapping certain fields for the import…
Can you please provide specific examples, we’re working now to improve the CSV import.
cc @david
The app doesn’t support importing the total, you need to import the line items and the total will be calculated.
Ok, I was trying to import historical data so that I could COMPLETELY migrate to IN without missing any data
