Will try this, I think i am getting the following error in apache error logs
Allowed memory size of 134217728 bytes exhausted (tried to allocate 32768 bytes) in /var/www/html/ninja5/vendor/symfony/error-handler/Error/FatalError.php on line 1, referer: https://in5.ghf.loc/
Didnât fix the issue, and i was getting the folliwng
38/47 [======================>-----] 80% Skipped installation of bin bin/openapi for package zircote/swagger-php: name conflicts with an existing file
45/47 [==========================>-] 95% Skipped installation of bin php-cs-fixer for package friendsofphp/php-cs-fixer: name conflicts with an existing file
Package swiftmailer/swiftmailer is abandoned, you should avoid using it. Use symfony/mailer instead.
Generating optimized autoload files
Class Razorpay\Tests\RegisterNachTest located in ./vendor/razorpay/razorpay/tests/registerNachtest.php does not comply with psr-4 autoloading standard. Skipping.
Class Razorpay\Tests\RegisterEmandateTest located in ./vendor/razorpay/razorpay/tests/registerEmandateTest.php does not comply with psr-4 autoloading standard. Skipping.
Class Razorpay\Tests\SignatureVerificationTest located in ./vendor/razorpay/razorpay/tests/signatureVerificationTest.php does not comply with psr-4 autoloading standard. Skipping.
Class Razorpay\Tests\RefundTest located in ./vendor/razorpay/razorpay/tests/refundTest.php does not comply with psr-4 autoloading standard. Skipping.
Class Razorpay\Tests\SettlementTest located in ./vendor/razorpay/razorpay/tests/settlementTest.php does not comply with psr-4 autoloading standard. Skipping.
Class Razorpay\Tests\QrCodeTest located in ./vendor/razorpay/razorpay/tests/qrCodeTest.php does not comply with psr-4 autoloading standard. Skipping.
Class Razorpay\Tests\PaperNachTest located in ./vendor/razorpay/razorpay/tests/paperNachTest.php does not comply with psr-4 autoloading standard. Skipping.
Class Razorpay\Tests\PlanTest located in ./vendor/razorpay/razorpay/tests/planTest.php does not comply with psr-4 autoloading standard. Skipping.
Class Razorpay\Tests\VirtualAccountTest located in ./vendor/razorpay/razorpay/tests/virtualAccountTest.php does not comply with psr-4 autoloading standard. Skipping.
Class Razorpay\Tests\PaymentLinkTest located in ./vendor/razorpay/razorpay/tests/paymentLinkTest.php does not comply with psr-4 autoloading standard. Skipping.
Class Razorpay\Tests\PaymentTest located in ./vendor/razorpay/razorpay/tests/paymentTest.php does not comply with psr-4 autoloading standard. Skipping.
113 packages you are using are looking for funding.
Use the composer fund command to find out more!
if [ â${IS_DOCKER:-false}â != âtrueâ ]; then vendor/bin/snappdf download; fi
Chromium binary already downloaded. Provide --force to download again.
One strange thing above which may be related, you shouldnât have needed to run composer install. If you copy over the files using the release zip the vendor folder should already include the third-party packages.
