But it is less likely to get answered on the yunohost forum.
I also found this ticket:
and tried to follow the instructions, but I think I’m doing something wrong.
Copy/Paste from my other thread:
Which says the config is here:
/etc/yunohost/apps/invoiceninja5/settings.yml
and the actual .env file is here:
/var/www/invoiceninja5/.env
I went into both files to remove the API_Secret but in both of them it says:
[ XXX is meant to be read-only ]
So I removed it regardless. Rebooted the server, but I am still getting the error:
403: Invalid secret on login
How do I remove the Secret from the login properly?
