Client Unable to Pay Invoice
Well as a designer you should have thicker skin if you think that was negative Hillel. I mean seriously… why the heck would a developer decide to put that function over in the bottom right corner?
Back to the issue at hand… Updating… How can I do this if I get those errors?
We welcome feedback when it’s presented without attitude
I’m sure other people on the forum will be happy to provide you more help…
Thanks.
So I can’t update it and you’re not able to help, am I understanding you correctly or have I misunderstood?
As I’ve said, if you’re able to stop making snide remarks I can try to help. Your last response was that I needed to develop thicker skin, which means you won’t receive my help.
Thanks. So I can’t update and you’re not willing to help.
I don’t think what I said was rude in any way. A simple statement of fact, nothing more.
I think we’ll have to agree to disagree.
As a next step I suggest manually copying over the latest release tar.
I can do that sure. Bit busy at the moment.
