Hi…
On version 5 self-hosted… logging in as a client! I cannot change pages 1…2…3… and so on or sort by unpaid/paid/Past due
any help appreciated
Hi…
@david any thoughts?
Should have mentioned v5.3.79-C78
Also tried a couple different PC’s and browsers
you may want to check your browser console for more information. It sounds like a path issue and livewire isn’t happy.
yes… i see it now… the url is going to https://domain.com/vendor/livewire/livewire.js
It gets a 404 because it doesn’t exist
is this corrected in a rewrite rule in .htaccess ?
I’m on the same version and had the same issue. This is a bug in my eyes. To resolve this I edited the /vendor/livewire/livewire/config/livewire.php file. Edit the lines that contain asset url and app url to your domain url. Syntax should be “https://www.yourdomain.com” with the quotes. Save it. Go back to your ninja root directory and issue the following command: sudo php artisan livewire:publish and test the client portal. This forces livewire to use the correct url.
From a bug perspective: livewire should be taking whatever the defined url was issued at the setup of InvoiceNinja. This goes for any url the app needs to function. I know it works fine out of the box as a root app for the webserver and issues as a subfolder for the app. I run my as a subfolder and had to make these changes for it to work properly. Either either way hopefully this gets addressed in future upgrades to the software.
Hmm I still get this error:
GET https://mydomain.com/vendor/livewire/livewire.js?id=940557fc56b15ccb9a2d net::ERR_ABORTED 404 (Not Found)
Also now I get get this error:
uncaught ReferenceError: Livewire is not defined
at invoices:752:223
Sounds like your still cached. Run sudo php artisan optimize then test again. Also make sure your url is what your public url is on your webserver.
yes… i actually had to reboot the server…
further ahead now… livewire errors are gone now…
now when i click on next or unpaid to sort i get a 500 error
“POST mydomian.com - Ce site web est à vendre ! - Ressources et information concernant mydomian Resources and Information. 500 (Internal Server Error)”
There is no message folder in livewire
Delete the contents of the bootstrap/cache/* folder. Should help.
ok just did it…
https://mydomian.com/invninja/public/livewire/message/invoices-table
POST
500 Internal Server Error
Maybe i’ll delete the cache folder and reboot… lets see…
It won’t hurt to try it.
All errors are gone now… just some report only errors
I can click on next page and unpaid … but it returns a 405 error
POST
405 Method Not Allowed
ok so now i have a 500 server error when i click on next or try sorting.
index.js:40
POST https://mydomain.com/invninja/public/livewire/message/invoices-table 500 (Internal Server Error)
Still wrong spot…
in my .env i have APP_URL as https://mydoman.com/invninja/public
my ASSET_URl is https://mydoman.com/invninja
in my livewire.php config I have set ‘asset_url’ => env(‘ASSET_URL’, null),
and ‘app_url’ => env(‘APP_URL’, null),
What am i missing here ?
this install was done using softaculous in cPanel, it did all work before updating.
Are there any details about the 500 in storage/logs?
ok really screwed it now… lol I made a typo in the livewire.php file… left off a ) bracket…
ran php artisan optimize… now i have crap…
Fatal error: Uncaught Error: Call to a member function connection() on null in /home/freebs/public_html/invninja/vendor/laravel/framework/src/Illuminate/Support/Facades/Schema.php:49 Stack trace: #0
How to fix ?? it just gets worse…
It may help to delete the bootstrap/cache folder
So which vendor does asset_url point to ?
My structure is myuser/public_html/invninja/public/vendor
or /myuser/public_html/invninja/vendor
I’m assuming the one with most of the sub folders in vendor is the correct assets folder to use
@david can you please advise?
ok so path is (i’m assuming) correct.
livewire.php - asset_url ‘asset_url’ => env(‘APP_URL’, null),
.env file - APP_URL=https://mydomain.com/invninja/public
Still get 500 when i change pages or sort in client portal…
last error in my laravel.log
production.ERROR: Trying to get property ‘client’ of non-object {“exception”:"[object] (ErrorException(code: 0): Trying to get property ‘client’ of non-object at /home/freebs/public_html/invninja/app/Http/Livewire/InvoicesTable.php:86)
have to get sleep now… thanks for any input
ciao for now
