From testing on my shared hosting instance using Invoice Ninja in a subdirectory, as long as you have defined the asset_url to the full path (invninja/public) I can see the system resolving all of the livewire assets correctly.
It looks like the latest softaculous release removed the asset_url => env(‘ASSET_URL’,null) helper that was there. So the fix should be to add this in and then run /update?secret=secret
Sorry for hijacking this post, but I have an identical problem here.
On the client portal, pdf invoices aren’t displayed because of an incorrect referral to lifewire.js
The invoice ninja software is installed in a subdirectory.
I have updated the lifewire.php as mentioned above, cleared cache, ran the artisan optimize command etc but that doesn’t solve the problem. Any other suggestions I could try?
