Upgraded. Same subdomain. Previous links sent in emails don’t work.
Tested this solution by simply changing view to payment, it didn’t work. Same 404 error.
@david any thoughts?
I’m not sure what is happening here, I haven’t used redirects like this to forward requests from v4 to v5, the suggested method is to install on a new domain and using the enable forwarding feature.
Guessing something changed between now and then if the work around worked for that poster. I see now the url structure is completely different.
A new subdomain wasn’t an easy change and I’m not sure why it’s not easier to replace v4 with v5 through an upgrade process. I get it’s a big code change but we invested in the our invoicing url and getting our customers to use that login, it’s also in our branding.
