Unfortunately, I only see a white screen after switching into react UI. Some had similar issues in the past here, and I got it too in version 5.5.95. Should be something added in the URL to make it work? BTW, no errors or warning in the chrome console.
@david any ideas?
Just to confirm, are you using the self updater? or the release.zip to install the application?
Since I am using Cloudron, It should be a self updater, I guess.
@david
Can you DM the link to your application please? I’m not sure how Cloudron bundles Invoice Ninja. There may be a platform issue.
I’ve sent you a DM with the link.
Any updates yet? Do you need support?
There is a fix for this in the latest release.
