I’m unable to do much with IN. I can’t get crons to work properly, can’t get quotes created or emailed, same with invoices. Nothing but issues since the update.
Are these the details for the 500 error you’re seeing?
Note: it’s helpful if you can try to keep the problem to a single post.
