Zipair pluging to invoice njnja
I am having a hard time getting this to work trying to connect https://zapier.com
the first part is easy but last part connecting Zapier to InvoiceNinja is complex i don’t understand your instruction.
Common Problems with Invoice Ninja on Zapier | Invoice Ninja | Help & Support | Zapier
I am very close I can’t get it to work.
https://invoice.6dysp.com/app/public/api/v1 , I get error
see picture…
https://photos.app.goo.gl/uQCBGt5LRieWaaMdA
You need to create a token in the web app and then supply the token in the Zapier config
I have created the token how do I add it to the Zapier config.
Provided an example that will be great…Picture below
https://photos.app.goo.gl/5mswz4v9fa9vdNQn6
When you create the token it should show you the random string to use
Hi Hillel , I have ramdom number but don’t know where to add it. Do i added to API URL at the end, /52552622552252111252
Please explain little more sorry learning as i go…
In the screenshot above where you have Zapier1
I deleted your screenshot because it includes your token, we don’t recommend sharing it.
Sorry, not sure why you’re still seeing an error.
Thank you, i just generated a new Token to be sure but I do get this error. Kindly, provided me the URL that should be set as (example) because I would like to use this can’t use looking to solve this.
https://photos.app.goo.gl/mW9kqdCwzUzSw4YH7
help… should I be looking for direct or set folder permission.
Try remove app/ in your URL
Same error : authentication failed: Got 404 calling GET https://invoice.6dysp.com/api/v1/ping?v2=true, expected 2xx.
V1 , upper case or lower case still same error.
The question, does it should be pointing to the directory folder?
Try adding /public before /api
We have tried that please look at the previous pictures you may see with the public folder.
https://photos.app.goo.gl/b8WGgSGhNvuKqPsL9
Try to remove app/ in your URL
It worked connected , Wow …
