Electronic invoices will be required in the EU from January 1, 2028. To this end, the data must be sent in an electronic format (XML). The hybrid format “ZUGFeRD 2.x” is currently recommended. When will this function be available?
And when can XML invoices be imported (Required from 1.1.2025)?
Time is now running out. In approx. 2 months, every company must at least be able to read e-invoices and the creation of e-invoices is also mandatory by January 1, 2028.
So far, I don’t know of any tool that only enables reading, but only complete solutions that already offer creation as well. I would like to avoid having to switch to a completely different system and would therefore like more information on when it will be possible to read and create e-invoices.
Sending an e-invoice seems to work without any problems except for 3 warnings, but the main problem is still reading incoming e-invoices.
From 01.01.2025, everyone must be able to process incoming e-invoices (from service providers, suppliers). There is no function for this in Invoice Ninja yet, or I haven’t found it yet.
Without the ability to process incoming e-invoices, I will have to look for another solution that will take care of everything, which would make Invoice Ninja superfluous.
Hence the question again: Will there be a way to process incoming e-invoices with Invoice Ninja this year?
I urgently need this function for 1.1.25!
