I have an nginx proxy manager that handle my domains and ssl certificates.
The InvoiceNinja App i running on another host with docker compose with the setup described here: GitHub - invoiceninja/dockerfiles: Docker files for Invoice Ninja
env:
APP_URL=https://ininja.domain.org
APP_KEY=base64:somestring
APP_DEBUG=false
REQUIRE_HTTPS=false
PDF_GENERATOR=snappdf
TRUSTED_PROXIES='192.168.179.165' # my local npm
docker compose:
services:
server:
image: nginx
restart: unless-stopped
env_file: env
volumes:
# Vhost configuration
#- ./config/caddy/Caddyfile:/etc/caddy/Caddyfiledocker-com
- ./docker/app/public:/var/www/app/public:ro
depends_on:
- app
# Run webserver nginx on port 80
# Feel free to modify depending what port is already occupied
ports:
- "8045:80"
#- "443:443"
networks:
- invoiceninja
extra_hosts:
- "in5.localhost:192.168.0.124 " #host and ip
app:
env_file: env
volumes:
networks:
- invoiceninja
- data_default
extra_hosts:
After i updated the docker images to a new version the links to the PDF or other files is wrong. See Screenshot
The App redirect me to a URL with the PORT i configured. If i manually open the link without the Port it works of course. In the customer portal i set the right URL to without port
I cant find the failure. Or i have to configure something in the Reverse Proxy?
i already change the port from 8044 to 8045 but the same behavoir
