Hey,
Here’s something else I noticed, purely cosmetic:
http://prntscr.com/f10pzd
Whenever the dashboard is loaded, it will keep the last view used (in my case, it’s the THIS YEAR) view as indicated by the arrow on the far right. But the labels shown are for LAST 30 DAYS. If I change the view, the labels change accordingly, it’s only when the dashboard page is accessed that this happens.
Also, I see that you kinda managed to fix the graph issue that I reported earlier. In the above example it is now showing the correct values for April and previous months, although it added May with zero values. Well, that works for me
