I can chown the files with the correct user and it works. but after a while the files seem to be back with the user ‘root’. When I run system health, this comes up as an error.
Is this a major issue and if so, what would be the step to resolve this?
@david any ideas, could this be caused by the cron?
@MrDatch
Most likely your cron user that is running the scheduler commands is being run as root,
When you configure your crons make sure you use the webuser, ie
sudo -u www-data crontabe -e
This will ensure the permissions say appropriate.
