[2021-02-16 07:47:26] production.ERROR: ErrorException [0] : /home/interninc/public_html/ninja/app/Models/Account.php [Line 1126] => Unparenthesized a ? b : c ?: d is deprecated. Use either (a ? b : c) ?: d or a ? b : (c ?: d) {“context”:“PHP”,“user_id”:0,“account_id”:0,“user_name”:“”,“method”:“GET”,“user_agent”:“Mozilla/5.0 (Windows NT 6.1; Win64; x64) AppleWebKit/537.36 (KHTML, like Gecko) Chrome/88.0.4324.150 Safari/537.36”,“locale”:“en”,“ip”:“NO.NO.NO.NOPE”,“count”:1,“is_console”:“no”,“is_api”:“no”,“db_server”:“mysql”,“url”:“/”}
YOUVE GOT TO BE JOKING!!! I spend the time to pull together required information so I can find out what Whoops! stands for and am blocked from adding the 3 other redirect link errors until I make more posts!!! Seriously!
How many posts must I make so I can show you the rest of the redirect links? It is very close to not worth it.
the other 3 links are banned until I post more. Do you mind waiting?
The link emailed does the same.
This is the 4th install…
Do you have a quick link to something that deciphers the log entry error code now that it has -something-? Google crashed for a split second.
Softaculous: With PHP V. 7.4, installed Ninja V. 5.1.31 in it’s own sub-folder. After install, and trying to access the admin or /ninja resulted in several oops and/or unknown errors. Errors were not recorded in “Errors” (raw) none in Raw Access. UNINSTALLED
Softaculous: Chose Version Ninja 4.5.35. and PHP 7.3. This loaded. OK, it’s the old version, maybe deprecated soon?
Will 5.1.31 be upgraded to work with PHP 7.4^ soon? Other 'wares on the server require PHP 7.4
