I saw a post that said only 5 companies can run on an instance, is that still true?
The idea is here that I would have multiple companies connecting to 1 installation of Invoice Ninja. Are you saying only 5 different clients can connect to 1 instance of Invoice Ninja?
Ok. I do see that I was only able to add 5 total companies so what is the recommended path for multi-tenancy, is it just 5 customers per install so after 5 you need a new server instance, or is there a way to force more clients on one physical install of Invoice Ninja?
