With the self-hosted version, when buying a white-label license, it would remove the logo on the login page. I’m on the enterprise hosted version but the InvoiceNinja logo is still on the login page and I don’t see any options to remove it or replace it with my logo?
Are you referring to the user (admin portal) login page or the client (client portal) login page?
I’m not sure what this would be called but the root… so https://v5-app1.invoicing.co/ this page for example.
Thanks, understood. Both the hosted and sefhosted versions of the app require showing the Invoice Ninja logo on the admin portal login screen.
Ah ok, I understand. However, interestingly enough on my self hosted v4, with the white label license, no InvoiceNinja logo shows (only with the license).
