Where do I find the square credentials for gateway setup?
Where do I find the credentials to set up Square as my payment gateway? I haven’t been able to find anything in the forums or elsewhere with this information.
Maybe this will help:
Yes, that is what I needed. Thank you!
@Pinedale_Computer what directions did you follow on the page? I’m trying to get Square setup and am struggling.
which credentials?
Personal access token or OAuth access token?
What goes in the Locationid box?
This is difficult without documentation.
Same problem here, I got the Access Token and App ID from Square, but what goes in the Location ID and Signature Key fields?
Thank you
@david can you please advise?
I’m trying to find the information requested by the OP
signature key is the only one with no documentation on square or IN
If david posted a video with the solution it doesn’t play for me on chrome or edge just the cursor hovering above IN tab
@sacredo and @JTW603 were you ever able to find the signature key?
It’s not listed in any documentation
I am hitting this issues and I see still no answer - how do we get the signature key? The video is dead.
Here’s the direct URL to the video:
https://www.loom.com/share/208467f5658e4e5db0bfbfcafd152553?sid=c2cc2067-7e70-46b7-b054-1a58fac9d7e8
