Weird Emails Settings Page Bug
Invoice Ninja v5.13.40, self hosted
I was busy setting up emails settings on a new install via the settings/ emails settings page and then the page seem to bug out and when I try and go in to that page it gives a blank screen, tried on different browsers. The strange thing is that it was opening up ok on the iPad at a different location, could it be blocking the page or be a cache thing, IP blocking? I can access other sections no problem just not the emails settings section. Also I have not entered any email details in the env. file yet?
Ran the following commands which did not help
php artisan cache:clear
php artisan view:clear
php artisan config:clear
php artisan optimize:clear
I believe the issue is being tracked here:
Just confirming that this is the fix and how do I go about applying it, file location?
https://github.com/invoiceninja/ui/pull/3387/commits/de4e8f329801c956243e5a4914fe243aabfedcc0
The fix should be included in the next version of the React web app.
Any Idea when that would be, is there a work around for now?
It should be available within a few days. You can access the settings in the desktop/mobile app: Mobile & Desktop Apps - Invoice Ninja
Ok Im using desktop APP and Im able to access the emails settings section, but having issues with setting up of emails, there does not seem to be a SSL Encryption option only a TLS? also what must i use in the Local Domain field and also must I enable the verify peer option?
400: Bad Request • Could not connect to SMTP server
If you need to use SSL then select TLS. The local domain field can be left blank.
Tried that still does not work, do you know if there are any issues using gmail ? Must I delete and try setting up the email settings in env. ?
If you’re using Gmail you need to create an ‘app password’
