Webhosting migration
I recently switched my Invoice Ninja, that is self-hosted, to another web host. I created a json and sql dump to be sure I wouldn’t lose any data. Once migrated to the new web host, I tried to import the json file for all my settings and data, but I’m unable to view my past invoices. When I go the invoices page, and a click on a old invoice, I get the error “Whoops, looks like something went wrong.”.
I tried also with the sql dump and I had the same issue. I can open/find all my other data (settings, quotation, expenses,…), but I’m not able to open the invoices. When I create a new invoice, that one works fine.
Any idea, what is wrong?
We recommend using mysqldump to transfer the app between servers.
Did you copy over the .env file, if the APP_KEY value changes it can cause errors.
I copied the APP_KEY from the old .env file, but I still have the same issue.
Do you see any details about the error in storage/logs/
Is this the log you need?
Which version of PHP are you using and which exact version of v4?
Only the latest version (v4.5.46) supports PHP 7.4.
That was it! I was running a older version (4.5.34) and PHP 7.4 was selected as default.
I changed it to PHP 7.3 and it worked again. I will upgrade it later on, to be on the newest version.
Thanks for the support! :slightly_smiling_face:
