Hi.
Can we dismiss the header pop-up permanently?
It will popup on every page reload
Thx
The Flutter web app will eventually be deprecated.
Is there a reason you’re using the Flutter web app rather than the React web app or the Flutter desktop app?
Hi Hillel.
I switched to a desktop app now.
Yes, the last time I accidentally clicked the React Web App button a few things didn’t work and I had trouble reverting it back.
Br
Thanks for the update!
There were some issues with the React app in earlier releases but the problems should hopefully be resolved now. If you want to try it again you can switch back by running this SQL query.
