viewing total amount of specific product on multiple quotes
Is there a way to view the total quantity of a product across multiple quotes? For example, i want to know how many “product x” are ordered for a date range. My goal is to use Invoice Ninja at work to eliminate writing orders by hand. I am not sure the best way to go about it.
You can use the quote item report to see that data.
In the desktop app you can group by the product to see the totals.
Thank you, that helped! In regards to using Invoice Ninja to take orders at work, would it be best to treat each order as quote vs an invoice? i will not be tracking payment, only using invoice ninja to eliminate writing future orders by hand.
I suggest testing both to see which works better for you.
