View PDF does not do anything
Version ie <v5.13.53>
Environment <Self-Hosted (Git)>
Checklist
  • Can you replicate the issue on our v5 demo site https://demo.invoiceninja.com or Invoice Ninja ? No
  • Have you searched existing issues? Yes, a few similar problems exist, but it did not help.
  • Have you inspected the logs in storage/logs/laravel.log for any errors? Yes, nothing found.
Describe the bug
After creating the invoices, client portal does not show the PDF for the latest invoice. Previous invoices are listed, but the current one does not show up at all. Nothing in the browser console when the “View PDF” button is clicked.
PDF generation is working, as all emails got PDF’s attached properly.
I tried all three ways of PDFs rendering - snappdf, phantom and hosted_ninja None of the options work!
Verified that snappdf exists - (Also did ./vendor/bin/snappdf download again download
Steps To Reproduce
go to any client portal and view latest invoice. It does not show PDF in portal. You can go to “all invoices” and download the invoice. But it doesn’t display in browser at all.
Expected Behavior
Should show invoice PDF in browser.
Additional context
Screenshots
Logs
Is there any way to force pdf invoice generation for latest batch of invoices?
I was able to isolate the issue here. I can provide a pull request for this, but it will revert some changes.
The strongest regression candidate is commit cbcf5f42d2, dated October 8, 2026 and included in v5.13.53.
For payable invoices using the newer portal flow, it changed View PDF from a direct dialog.showModal() call to open($event) through a new shared JavaScript helper, and moved the PDF dialog into an Alpine teleport. That puts the recent change directly on the click path you described. The older behavior is present in v5.13.44; the new behavior is present in v5.13.53.
The fix works locally on my server.
Pull request on Github:
Thanks for creating the PR!
