The view button is missing from the documents area, the only opts are download, rename or delete. No error message, just button/opt is no longer there… Is this a feature that will be coming back or can it? Do not want to waste storage space on devices.
I needed to remove the view option due to header changes, @david maybe we can support viewing documents using a one-time password?
@hillel if you download the image, can you then perform the view action locally?
That’s true but I think users would like the option to view documents without first needing to download them.
I strongly believe that the view button has to come back, I would like to make the decision for myself to download the document or not. For instance I might be working from a remote location on a machine (which I often do) that is unsecured or not under my control for which I do not have rights to download or for that matter want to save a file locally outside of my secure session… Anyhow it opens up a security issue where you might leave files in a cache somewhere that could have sensitive information on it, this is not ideal.
So I would like to respectfully ask if this feature could be put back again.
Kind Regards
George V
Just following up, is there a way the view button can come back?
GV
Since the View document option has disappeared, downloading a document (PDF) generates an empty (0 bytes) file. Not sure if these issues are related but there seems to be no way to view your stored documents at this time? Any other way?
Best regards,
Frank
Thanks for the feedback, we’ll look into it.
Any progress on the empty document issue ?
Regards
George V
