Hello, we ran a test migration from V4.5.50 to V5.4.11 a few days ago,
The test migration went mostly great, (had to increase max_allowed_packet field in /etc/my.cnf) However we would appreciate some feedback on below.
We have a few noticeable issues relating to migrated data:
Imported Recurring invoices are marked as pending except for one which seems to be the first one imported as it is numbered 1 (this one is marked active).
Imported Recurring invoices have no invoice history, i.e. no invoices generated prior to the migration are listed in the “invoices” section of the Recurring invoice. Schedule section of the recurring invoice has no entries for previously generated invoices only dates for upcoming ones.
Imported Clients have no contacts listed in the “table view” unless we open the clients click edit then save. Additionally after the migration completed the email mentioned that All our “clients without a single primary contact”.
Markdown parser for product descriptions in v4 allowed for no space after “#” and no requirement for double space prior to new line. In v5 those 2 are required and of course we used the v4 way… meaning that all Descriptions in migrated Products and Tasks as well as Invoice, Recurring invoice and Quotation line items, now don’t look good enough to be presented to the client.
Can the migration script be updated so it can append a single space to hashtags or groups of hashtags and prepend 2 spaces to carriage returns? Or whatever the equivalent is?
While Product descriptions can be manually fixed, the line items for existing invoices, quotes etc would be impossible to fix by hand due to the sheer volume. We are willing to try messing with MySQL directly either in v4 or v5, but would need a bit of guidance from devs as am not sure what that query would even look like
No errors were detected in any of the usual logs.
The upgrade path was Production instance > Cloned To another VM > Cloned VM Updated including PHP 7.4 > Invoice Ninja 4.5.16 dev branch updated to Invoice Ninja v4.5.50 zip archive.
The migration doesn’t transfer any history, so the recurring invoices are brought over, but are considering pending until they send from the first time from v5.
This can sometimes happen, running
php artisan ninja:check-data --fix=true
should resolve this
v4 had partial markdown support, in v5 it is full markdown support so this is the reason you are seeing this particular issue. However from my tests, the markdown appears to have come across ok. Can you confirm in Settings > Account Managment you have markdown in PDF support turned on?
If you do, please share a screenshot of how the invoice is appearing post migration.
After runing sudo -u www-data php artisan ninja:check-data --fix=true
We get this:
2022-07-27 07:14:25 2022-07-27 07:14:25 Running CheckData... on Connected to Default DB Fix Status = Fixing Issues
2022-07-27 07:14:25 0 clients with incorrect balances
2022-07-27 07:14:25 0 clients with incorrect paid to dates
2022-07-27 07:14:25 0 contacts without a contact_key
2022-07-27 07:14:25 0 clients without any contacts
2022-07-27 07:14:25 0 vendors without any contacts
2022-07-27 07:14:25 0 invoices without any invitations
2022-07-27 07:14:25 0 quotes without any invitations
2022-07-27 07:14:25 0 credits without any invitations
2022-07-27 07:14:25 0 recurring_invoices without any invitations
2022-07-27 07:14:25 0 wrong invoices with bad balance state
2022-07-27 07:14:25 0 users with duplicate oauth ids
2022-07-27 07:14:25 Done: SUCCESS
2022-07-27 07:14:25 Total execution time in seconds: 0.087177991867065
In Address.php line 54:
Email "" does not comply with addr-spec of RFC 2822.
Not all our clients have emails or even contacts or contact details but most of them do.
Cleared Cache, Logged Off and on ran php artisan optimise, same issue, no contact names, emails etc in the Clients table view.
V5 requires a space between hashtags and text, as well as 2 trailing spaces and return for a new line, in V4 that was not a requirement hence the below mess:
That’s why I’m hoping to run a mysql query,
The query would append a space to hashtags that are not immediately followed by another hashtag or a space.
And another query that would prepend every new line with a double space?
I’m hoping that would fix it.
Oh that’s ok, this is a test migration, there is live data and the company is set to active but the instance is not able to email, process payments etc.
That is going to be tough to split instance of #, ## and ### apart due to partial matching… You could try the following ensuring you do a full DB backup in case this does not work
Nice, Could you please help with code for Recurring, Quotes and Products as well?
Had to play around with Regex but got it eventually with negative lookahead and negative lookbehind . Also had to do newlines in 2 steps, doing it in a single step just prepended the lines with 2 spaces instead of appending them.
Tried running it against Recurring Invoice myself by changing the query and a few other bits but ended up nuking all items in Recurring Inv haha.
@david
Thanks, I could swear that’s what I did when I nuked the Recurring but seems to have worked this time, except Products
I get
PHP Error: Call to undefined method Imdhemy\Purchases\Product::query() in
/usr/share/nginx/invoiceninja/vendor/laravel/framework/src/Illuminate/Support/
Facades/Facade.php on line 337
Any suggestion re: contacts not appearing in the client list table, until contact is edited and saved again?
We only have about 100 contract clients whose details need to be up to date for recuring invoices, email notifications etc so in our case it can be fixed manually.
However if someone is migrating a large amount of regular clients with recuring invoices + email reminders enabled etc, would not having a default contact assigned not affect them majorly?
