Hello, I just tried installing the updated Invoice Ninja on my server via Softalicious and after attempting the install, I ended up getting a server 500 error. I then tried rolling back my server to multiple backups including full, file, and database restores with and without the assistance of my host, however the server 500 error message persists.
It seems that somehow the install altered my server settings so that even my system backups of Invoice Ninja no longer function at all.
My host says I’m getting this error:
[07-Jul-2021 19:33:32 UTC] PHP Fatal error: Uncaught Error: Class ‘Request’ not found in /home/[REDACTED]/app/Exceptions/Handler.php:106
Stack trace:
#0 /home/[REDACTED]/vendor/turbo124/framework/src/Illuminate/Foundation/Bootstrap/HandleExceptions.php(112): App\Exceptions\Handler->render(Object(Illuminate\Http\Request), Object(Symfony\Component\Debug\Exception\FatalThrowableError))
#1 /home/[REDACTED]/vendor/turbo124/framework/src/Illuminate/Foundation/Bootstrap/HandleExceptions.php(89): Illuminate\Foundation\Bootstrap\HandleExceptions->renderHttpResponse(Object(Symfony\Component\Debug\Exception\FatalThrowableError))
#2 [internal function]: Illuminate\Foundation\Bootstrap\HandleExceptions->handleException(Object(Symfony\Component\Debug\Exception\FatalThrowableError))
#3 {main}
thrown in /home/[REDACTED]/app/Exceptions/Handler.php on line 106
Any assistance is apprecaited. I’ve also tried doing an uninstall and reinstall via softalicious however when I did a softalicious install, the system rejected the admin credentials that were created. I also tried resetting via softalicious, had no luck. The password reset functionality did not work at all, and when I try to manually connect the new install to my old database - I get the 500 error again.
Any assistance is appreciated.
