[self-hosted, shared hosting]
Trying to follow the steps listed here
https://invoiceninja.github.io/docs/migration/
and have updated my v4 to the latest version but getting some issues with v5 setup which I have done on a different location as v4.
V5 setup (5.1.14)
- I have uploaded the whole v5 from invoiceninja.org via FTP to a fresh location
- PHP is on 7.3
- Have yet to run through the initial setup, getting a 500 error page
- Turned debug on and looks like a database connection issue
- v5’s storage/logs does not contain anything at the moment
Some questions:
- Do I delete the default .env file included in the package? It has some default random values inserted like user ‘ninja’@‘localhost’.
- Do I need to edit the .env.example file manually with the database and other details via notepad? If I’m not wrong, v4 setup gets the values when entered on the form via the website setup.
- For the fresh setup process for v5, do I enter the same database as my v4? afraid it might wipe out existing data so asking first.
My .htaccess file in case there’s any issues with it
<IfModule mod_rewrite.c> RewriteEngine On RewriteRule "^.env" - [F,L] # RewriteRule "^storage" - [F,L] RewriteRule ^(.well-known)($|/) - [L] RewriteRule ^(.*)$ public/$1 [L] </IfModule>
# https://github.com/h5bp/server-configs-apache/blob/master/dist/.htaccess
# # INTERNET EXPLORER #
# | Iframes cookies |
# Allow cookies to be set from iframes in Internet Explorer.
# https://msdn.microsoft.com/en-us/library/ms537343.aspx
# http://www.w3.org/TR/2000/CR-P3P-20001215/
<IfModule mod_headers.c>
Header set P3P "policyref=\"/w3c/p3p.xml\", CP=\"IDC DSP COR ADM DEVi TAIi PSA PSD IVAi IVDi CONi HIS OUR IND CNT\""
</IfModule>
# # MEDIA TYPES AND CHARACTER ENCODINGS #
# | Character encodings |
# Serve all resources labeled as `text/html` or `text/plain`
# with the media type `charset` parameter set to `UTF-8`.
# https://httpd.apache.org/docs/current/mod/core.html#adddefaultcharset
AddDefaultCharset utf-8
# Serve the following file types with the media type `charset`
# parameter set to `UTF-8`.
# https://httpd.apache.org/docs/current/mod/mod_mime.html#addcharset
<IfModule mod_mime.c>
AddCharset utf-8 .atom \
.bbaw \
.css \
.geojson \
.js \
.json \
.jsonld \
.manifest \
.rdf \
.rss \
.topojson \
.vtt \
.webapp \
.webmanifest \
.xloc \
.xml
</IfModule>
# # WEB PERFORMANCE #
# | Compression |
<IfModule mod_deflate.c>
# Force compression for mangled headers.
# https://developer.yahoo.com/blogs/ydn/pushing-beyond-gzipping-25601.html
<IfModule mod_setenvif.c>
SetEnvIfNoCase ^(Accept-EncodXng|X-cept-Encoding|X{15}|~{15}|-{15})$ ^((gzip|deflate)\s*,?\s*)+|[X~-]{4,13}$ HAVE_Accept-Encoding
RequestHeader append Accept-Encoding "gzip,deflate" env=HAVE_Accept-Encoding
</IfModule>
</IfModule>
# Map certain file types to the specified encoding type in order to
# make Apache serve them with the appropriate `Content-Encoding` HTTP
# response header (this will NOT make Apache compress them!).
# If the following file types wouldn't be served without the appropriate
# `Content-Enable` HTTP response header, client applications (e.g.:
# browsers) wouldn't know that they first need to uncompress the response,
# and thus, wouldn't be able to understand the content.
# http://httpd.apache.org/docs/current/mod/mod_mime.html#addencoding
AddEncoding gzip svgz
</IfModule>
# Compress all output labeled with one of the following media types.
# IMPORTANT: For Apache versions below 2.3.7 you don't need to enable
# `mod_filter` and can remove the `<IfModule mod_filter.c>` & `</IfModule>`
# lines as `AddOutputFilterByType` is still in the core directives.
AddOutputFilterByType DEFLATE "application/atom+xml" \
"application/javascript" \
"application/json" \
"application/ld+json" \
"application/manifest+json" \
"application/rdf+xml" \
"application/rss+xml" \
"application/schema+json" \
"application/vnd.geo+json" \
"application/vnd.ms-fontobject" \
"application/x-font-ttf" \
"application/x-web-app-manifest+json" \
"application/xhtml+xml" \
"application/xml" \
"font/opentype" \
"image/svg+xml" \
"image/x-icon" \
"text/cache-manifest" \
"text/css" \
"text/html" \
"text/javascript" \
"text/plain" \
"text/vtt" \
"text/x-component" \
"text/xml"
</IfModule>
</IfModule>
