I used api keys for Integromat and Zapier but those don’t seem to be migrated. I could add new api keys but then a new api key is generated. I’m also wondering about the keys for the online payments gateway now. Is it really migrated…
So my questions are:
Are the old api keys not migrated from v4 to v5?
Is there a way to modify the api keys so that I can replace it by the ‘old’ values?
Are online payments gateway keys migrated from v4 to v5?
Yes the keys are migrated. If you want us to confirm send us an email to contact@invoiceninja.com and we can take a look at your account.
Please note, with Mollie, we only have the Credit Card working. Our current sprint includes 3 types of Mollie ACH payments Bank Transfer, Bancontact and KBC
Just an remark about search in Zapier. When searching you should leave out the space between “invoice ninja”. If you search for "invoiceinja"you get the v5 version of Zapier InvoiceNinja module in the results list.
I made a feature request on Github, please give some thumbs up there:
By the way. I’m not sure if I find this the correct way. I’m on the hosted. In a SAAS one would expect that functionality like this wouldn’t get ommited after an update. This shouldn’t be a feature request but a bug fix as online payments is one of the core functionalities in online invoicing.
In v4 by supporting Mollie we automatically supported all of their gateways because it was considered an ‘offsite’ gateway. @david@ben is this different with v5?
Thanks! If it isn’t too hard we should consider adding an option to select offsite vs onsite. In general, offsite gateways are much simpler to implement and can provide added functionality.
