I thought that I should use a bottom alignment instead here, but no matter what I’ve tried thus far it ends up not showing up properly and aligned with the bottom of the page.
How would you handle a footer bottom alignment such that it stays anchored at the bottom of pages?
Thanks so much guys - While this is not entirely related: I also shared a private support request with a video via the system since I didn’t want to share the specific info in it. Hoping you might be able to share a snippet as well for that. The gist is trying to keep the top product / services / items table header in a fixed position while fiddling around with the upper fields. Overall I’m working off of an existing designing that I’ve been using for many years and have too many envelopes that match the layout to change now…
This was requested previously and I always try to convince people that this is not a good solution & it shouldn’t be used. It’s not reliable, content may overlap, etc.
However, if you still want to do it, here’s how you can:
