No scheduled commands are ready to run.
But in the invoice ninja v5 interface i get the error “the cron needs to be enabled”. refreshing the data doesn’t change anything. Latest version of invoice ninja on Ubuntu 20 with nginx
This works for me when running with php7.4-fpm. Because I have a blog with grav installed that has higher php dependencies, I must specify php7.4 everywhere in IN configurations. I suggest you make it a practice too if you run multiple services on your system.
Gave that a go and when i went to my invoiceninja instance the red alert had gone. Not sure if it was that that fixed it though as when I change back to my old cron its still gone
I think it may have fixed itself overnight - the original cron task i setup seems to work too and it hasn’t reappeared
