I have used:
https://docs.invoiceninja.com/api.html
to connect our in house system to v4 of hosted Invoice Ninja. We rely on the API connection to bill our customers through Invoice Ninja and it’s a manual mess/nightmare without the ability to use the API, it’s a requirement actually for any billing system we use. Today, it felt forced (not sure if it was 100%) forced that we move to v5, so we did.
I am certain all our API calls are now broken but I haven’t verified yet. It seems that the only API docs I can find are here:
https://app.swaggerhub.com/apis/invoiceninja/invoiceninja
There is lots of code on the screen but in my opinion, this is severely limited in comparison to the v4 docs. There also doesn’t appear to be a PHP SDK unless the old one has been updated.
Any help or baby steps would be really appreciated in terms of getting our API calls converted from v4 to v5 so we aren’t stuck doing manual invoices next month.
Right now we use the PHP SDK for v4 as far as I remember and we basically just create invoices, not much else. It’s been a while since we coded this into v4 so, honestly I’m just at a loss looking at these new docs. Doesn’t seem to be any instructions, just a bunch of code, I’m sure I’ll make sense of after staring at it for hours. But, some step by step or example client code would be fantastic.
Thanks in advance for any help.
