When I upgraded, i was shown a 500 error:
Trait ‘Awobaz\Compoships\Compoships’ not found
I checked the vendor folder and it seemed it missing quite a few packages? I have a feeling composer updates are not happening when updates are triggered.
I am using BlueHost Shared Hosting and using softalicious to install Invoice Ninja. After the 500 error I went into softalisious and forced an update to V5.4.4 which fixed the 500 error. So that Is no longer an issue (I hope)
I now however noticed I can not switch to the React App and am presented with an SQL Error:
Unknown column ‘set_react_as_default_ap’ in ‘field list’. Is this a new column added to the ‘accounts’ table? Can I just add this table manually? Is there likely other tables that where not updated? Is there a reason why my updates are not making changes to my database tables not composer? I expect it could be something to do with my hosting, but ideas of things to look at would be great.
Thanks for quick reply. Can you confirm what this does? is it something that should have been run automatically when updating to 5.4.4 from (i think) ~5.3?
Thanks for clarification. Does this apply to ALL updates that become available? eg should I never update via the ‘update’ prompts from within Invoice Ninja and ONLY update when an update is available via Softaculous?
SQLSTATE[42000]: Syntax error or access violation: 1064 You have an error i
n your SQL syntax; check the manual that corresponds to your MySQL server v
ersion for the right syntax to use near ‘json null’ at line 1 (SQL: alter t
able schedulers add action_name varchar(191) not null, add action_clas s varchar(191) not null, add parameters json null)
In Connection.php line 495:
@hillel@david Seems Recurring Invoices have no ‘next send dates’ and if preview the settings, it says the next send for the schedule is todays date, which is incorrect. If I check the clients portal however, the recurring invoice Next Send date is correct.
It looks like you have a lot of migrations which have not run on your system. Can you try running /update?secret=secret this will attempt to run the migrations missing on your system.
I assumed you meant run that as a url query? I ran it but it doesn’t appear to have made a difference, still getting errors in quite a few places. Im pretty sure it is an issue with migrations not having run as I have been updating invoiveNina though the in-app prompts rather than through softaculous Which I didn’t realise is something I shouldn’t be doing.
Is there anything else I can do to force the migrations to run or any other recommendations?
EDIT
Not sure if it perhaps is something with the softaculuos version specifically? I just tried a new install on separate subdomain but softaculous fails to install v5 with an sql error. Hope this might help.
I understand the issue here. You’ll need to download the latest release file and overwrite your current installation. There was an issue with the migration in that particular version which we later corrected with json columns.
After you overwrite the files, the migration will complete correctly.
