I’m trying to install the self hosted version, but I am using FTP. I’m not familiar enough to use the other method described in the install post. I’ve done this in the past with V4 and it worked ok for me.
I downloaded the -release version of 5.0.13 to my computer. I extracted all the files. Then, uploaded the files in their existing structure to my webhost to a new folder /public_html/billing5.
Oops, something doesn’t look right!
Make sure all requirements are satisfied.
Required extensions
mysqli gd curl zip gmp openssl mbstring xml bcmath
PHP version
OK
Writable .env file
OK
NPM status
I could not find NPM anywhere. Is it installed?
Node status
I could not find Node anywhere. Is it installed?
I’m not sure where I’m stuck. Is NPM and Node something I need to install separately, or something needed in my PHP settings on my server? Is installing V5 in this method not even supported?
I have downloaded V5.0.17 and uploaded it to my server.
I visited /public/setup and can see the setup form.
After filling out each section and clicking the TEST button, I get “Oops, looks like something isn’t correct!”.
I have confirmed that my database is setup and ready to go. I can connect to it with other software.
If I click the Submit button, it takes me to a “500 | Error” page.
Other than uploading all the files to my server (maintaining the folder structure), is there anything else I’m supposed to be doing? Do I need to set permissions on any folders? Run any other install before the setup?
Server Logs? Or is there a log being created in the subfolders?
Also, the instructions you sent above talk about dragging the folders to the web root.
Is it acceptable to be using a subfolder? www.domain.com/billing/?
I’ve also tried a subdomain, https://billing.domain.com. Both methods are coming up with the same errors.
Hillel, I really appreciate your help!
I was able to get the install to work. I was not able to get a successful PDF test though.
Now, I am trying to migrate from V4 to the new V5.
Do the database names/passwords need to be the same for each version?
I run the migration (V4 app) and I get " Whoops, looks like something went wrong."
Are there any other settings I need to change/update before running the migration?
Well, I’m having other issues now. Trying to change anything in V5 I get 500 Errors.
Specifically, if I attempt to add my phone number to my user account, or change the Accent Color. It asks for my password, then shows a 500 error.
Also, I can’t find where to change my user password on V5.
Ideas?
