In V4 if I converted a quote to an invoice, it switched the view from the quote to the invoice. In V5, converting a quote to an invoice doesn’t take you to the invoice. Is that intended behavior, or is it broken? Thank you.
This is the intended behavior.
After converting the quote an option to view the invoice should appear.
